Only 2 Years on a WaterPump?!?!
Old Dec 26, 2008 | 12:20 PM
dieselloco427's Avatar
Is two years about the average lifespan of a waterpump on a 3VZ-E? Of course it just went out of the 2yr warranty and I don't know if the shop put a reman or oem waterpump in it. So - looks like I've got to replace it and I'm not going with a reman. I'd like to go with OEM (asin I think), but its about 90 bucks for one from the dealer. Whats the next best thing? Cardone Select? Beck/Arnley? And I might as well do the timing belt and t-stat too.
Old Dec 26, 2008 | 12:35 PM
abecedarian's Avatar
waterpump should last a lot longer than that. wonder if they used tap water instead of distilled?
Old Dec 26, 2008 | 01:13 PM
DeathCougar's Avatar
Its not really a matter of tap or distilled, its a matter of the quality of water pump. Simply put, cheap parts yield cheap quality. If you put an aftermarket cheap reman pump in there, 2 years is about all you can expect out of it.
Go to www.toyotapartsales.com and order one from Phil (Strap22) GET AN OEM ONE. Saving $20 isn't worth the time you will be spending tearing it all apart.
Old Dec 26, 2008 | 01:29 PM
Junkers88's Avatar
Yeah you need to use OEM parts. When my factory alternator died at 172,000 miles (give or take a few) I tried to save 50$ and get an "off brand". It lasted less than 1000 miles so I returned it on the warrantee and paid the extra for an OEM replacement.
Toyota made this stuff to last, trust in that.
Old Dec 26, 2008 | 01:50 PM
I suppose I should've first asked what failed in the waterpump before jumping to the distilled vs. tap water.
Old Dec 26, 2008 | 02:40 PM
Alex 400's Avatar
It is true that tap water has impurities in it and you shouldn't use it straight, but it's water and if you are using a good quality antifreeze I think you would be alright.
Old Dec 26, 2008 | 02:44 PM
22REw/HP's Avatar
Go Aisin, so you wont have to do this in two years!! J/K
Old Dec 26, 2008 | 03:35 PM
Bigblock's Avatar
OEM Only!
Bigblock
Old Dec 26, 2008 | 03:41 PM
So it looks like I will be doing OEM. The bearing is starting go go out on it. I get that shrill squealing sound from the waterpump area. I've taken the belt of the alternator, p/s pump and a/c and it still makes the squeal. Sometimes it makes it all the time, sometimes its sparatic, but mostly after I've done a hard acceleration or when its cold in the morning. *Edit: I found an Asin pump. Is it worth getting the warranty (1yr for $10.64, 3yrs for $17.74 or Lifetime for $24.83) The pump itself is $80
Old Dec 27, 2008 | 12:19 PM
Jay351's Avatar
Oem all the way. I never like to skimp on engine parts, toyota parts are just better quality. Worth the price!
icentropy
Sep 16, 2020 02:47 PM
jasonty
41
Dec 23, 2018 01:00 PM
Road Bull
Oct 10, 2015 04:55 PM
irritech
Jul 27, 2015 05:15 PM
daddio
Jul 18, 2015 10:20 AM
