battery/alternator problem
Old Dec 19, 2008 | 01:10 PM
88wildrunner's Avatar
my truck is having issues with recharging the battery while driving, i have a new yellow top in it (only 6-8 months old), i check the volts on the battery wich was 12.5-13 volts and i checked the volts coming off of the alternor which was 12 volts, i put the volt meter on the bolt that the power cable goes to. i checked the charge fuse and it is good.
the problem started a few days ago when the charge and brake light came on while driving, i charged the battery overnight and the charge light still came on, as i drove it to make sure it just wasnt a glich with the idiot light, the stereo turned off and then the truck died. also the spark plug wire to the number 2 cylinders was fried so i replaced it and still the problem persists.
i cant seem to find the root of the problem does any one have any ideas or have had this problem before.
Old Dec 19, 2008 | 01:28 PM
1stgen4gunner's Avatar
There is a wire under the Alternator that is screwed into a ceramic piece, make sure it is tight and screwed in all the way, I had a similar problem and that's what it was, you should go outside at night and start it, if you see sparks near the alternator then that's what it is. Don't forget to rev it a little.
Old Dec 19, 2008 | 02:06 PM
one2high's Avatar
When your truck is running, you should have between 13.8-14.2 volts at the battery. If everything died while the truck was running, your alternator is toast!!
Old Dec 19, 2008 | 02:26 PM
okie81's Avatar
x2 .... I had the same problem as well, the ceramic piece breaks and causes it to ground to the alternator casing. Pretty easy fix though if that's the case.
Old Dec 19, 2008 | 04:00 PM
where is the wire on the bottom i looked at mine but didnt see any wire on the bottom of the alternator
Old Dec 19, 2008 | 05:09 PM
Originally Posted by yota4runna
On Toyotas, when the alternator quits charging, both the brake light and the charge light come on. If you're lucky, the alternator brushes have worn out, and they're an easy fix.
how do you fix the brush's, do you ahve to replace the entire alternator or is there a rebuild kit?
Old Dec 19, 2008 | 05:25 PM
86Toyrunna's Avatar
ya system voltage while running should be betwwen 13.5-14.5ish.. if the batt is fullly charged on its own, no surface charge it should be sittin at 12.6v. id deff check all your gounding connections. dont know if your local part store has the ability but if you have any doubts take it in and they can throw it up on a test bench and tell ya if its fubared
Old Dec 19, 2008 | 05:33 PM
yeah i guess ill take the alternator in to have it checked. thanks for the replys ideas guys
Old Dec 19, 2008 | 05:44 PM
Windsor's Avatar
You can usually buy brushes for rebuild purposes, yes.
If the alternator is getting noisy, then it's a rebuild kit -and- a bearing (or two).
SubiKing
Aug 21, 2021 03:57 AM
theking11863
Mar 19, 2016 09:36 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
