changing crank seal
Old Dec 24, 2008 | 06:56 AM
wbthornton88's Avatar
changing crank seal
What all would I have to take off to replace a crank seal on the front of the engine? I have a oil leak coming from there.
Old Dec 24, 2008 | 08:24 AM
Well I need to know how to remove a crank pulley. How do I keep it from turning while turning the bolt?
Old Dec 24, 2008 | 08:27 AM
ROCK LIZARD's Avatar
First you need to tell the forum what engine and vehicle you have.
Old Dec 24, 2008 | 08:28 AM
95 toyota pickup 3vze
Old Dec 24, 2008 | 08:48 AM
Tubbyfatty's Avatar
Impact gun on reverse.
Old Dec 24, 2008 | 11:38 AM
can someone tell me where to locate coil wire?
Old Dec 24, 2008 | 01:01 PM
RaginYota's Avatar
Not to sound like a jerk, but I would recommend that you pick up a manual. It will answer 99% of the questions you are going to have. Since you are going to have to remove the timing belt to replace the crank seal and depending on how many miles you have your engine, you might as well replace the timing belt and water pump. Good luck
Old Dec 24, 2008 | 01:27 PM
desertcox05's Avatar
i thought my front seal was leaking once and when i was puting it all back together i noticed the oil pan bolts were loose. i probably didn;t have a seal leak afterall.
jasonty
41
Dec 23, 2018 01:00 PM
redneck17
Jul 17, 2015 07:44 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
HRDC0R19
Jul 5, 2015 06:43 PM
