Manual Aisin Hub Rebuild?
Old Dec 20, 2008 | 10:14 AM
kmat123's Avatar
We have had some nasty weather here in Oregon over the last couple of weeks so I have been in 4WD more than usual. When my hubs are locked I'm occasionally hearing a squeal coming from the drivers side, which leads me to believe my driver's side hub may need rebuilding. Using the search feature I came across this link: http://forum.ih8mud.com/79-95-toyota...b-rebuild.html, which looks to be a pretty good write-up of the job. In terms of tools it looks like I will need a good set of snap ring pliers and a brass drift for the cone washers. What is a good source for new gaskets for these hubs? Also, for those of you who have done this job, how extensive is it and any suggestion to make things easier. Thanks!
Old Dec 20, 2008 | 10:26 AM
Yoda's Avatar
Dealer for the gaskets. It's a 1 banana job. Look out for the little BB. I do mine on a bench with rags on it.....keeps the little things from rolling away
Old Dec 20, 2008 | 10:34 AM
iamsuperbleeder's Avatar
that's the step-by-step is the one I went by, and it's a good one!
once you do one side, you can do the other without even reffering to the write up; they're that easy to do!
here's my little exprience (I did a little more than just the hubs, but you get the idea)
https://www.yotatech.com/forums/f116...ry-day-156896/
good luck!
Old Dec 20, 2008 | 11:11 AM
space-junk's Avatar
easy as pie...
https://www.yotatech.com/forums/f116...ild-up-158644/
Old Dec 20, 2008 | 11:52 AM
Originally Posted by space-junk
Hey I looked for your thread too; I was going to post a link to it on here... but mine was easier to find for me
Old Dec 20, 2008 | 04:41 PM
space-junk's Avatar
just bookmark it trav...
Old Dec 20, 2008 | 07:47 PM
Well Troy ( I think, right? ), I don't need it now, I could rebuild em blind-folded!
Beside, I did mine before you did
Old Dec 20, 2008 | 08:01 PM
jsn_stockard's Avatar
It is prob not the hub, you need to grease your spindle bushings. Do a search on here for a spindle grease tool. I cant remember who designed it, but I built one and it fixed mine.
Old Dec 21, 2008 | 12:44 AM
scuba's Avatar
OH OH, I WANNA PLAY, I rebuilt my hubs too !!!
https://www.yotatech.com/forums/f116...ebuild-157649/
Between the 3, you should be fine
jaretstuff
Aug 4, 2015 02:08 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
PlayAwhile
Jul 20, 2015 11:36 AM
ItsJustD
Jul 7, 2015 07:49 AM
