Can you remove a fixed antenna?
Old Dec 22, 2008 | 08:02 PM
xzyragon's Avatar
Well, if you have read my previous post, I need to fix my car. To cut off the excess sheetmetal up front to weld on some new pieces, I need to remove the front passenger side fender. However, attached to that fender is the antenna, and I believe that I have to remove it to take off the fender. How exactly do you do this?
Thankyou in advance
xzyragon
Old Dec 22, 2008 | 08:11 PM
scuba's Avatar
There should be a nut on the underside that should let it be removed...
Old Dec 22, 2008 | 08:38 PM
the_ocho's Avatar
sawzall
Old Dec 22, 2008 | 08:40 PM
xzyragon's Avatar
nut on the underside of what?
Old Dec 22, 2008 | 08:42 PM
the_ocho's Avatar
the antenna is attached to the fender by a backing nut. to remove the fender remove all the bolts along the hood line the ones inside the door jam and the ones holding the inner fender to the outter fender and im sure there are some more. once its off disconnect the antenna
thedude42's Avatar
under your "gap gaurds" (the pieces of rubber that keep mud etc... out of your engine and reach up on the fender there should be a nut that connects to the antena i had to tighten mine a few times
Old Dec 22, 2008 | 08:44 PM
scuba's Avatar
There should be a nut on the top or bottom of the mast assembly...
So underside of the fenderrr......
Old Dec 22, 2008 | 08:47 PM
the_ocho's Avatar
HEy guys the OP wants the fender off not the antenna tighter
Old Dec 22, 2008 | 08:51 PM
thedude42's Avatar
hahahaha i am so dumb!
thedude42's Avatar
wait no he wants both so we were right
Old Dec 22, 2008 | 08:55 PM
sa51's Avatar
Originally Posted by the_ocho
sawzall
thats the solution to all life's problems
when i took my fender off, i just yanked and pulled till the rubber thing bent and fell off
it looks fine, i taped whatever was previousyl broken under the fender, and sprayed the little thing the antenae threads into to match the truck. theres a slight gap now but it looks better then before, when it would just flop over
Old Dec 23, 2008 | 07:54 AM
xzyragon's Avatar
its OK
you can take the fender off while the antenna is still attatched, you just gotta have a cord hanging from the fender
the nut just removes the antenna from the connection to the body, but is still attached through its chord
icentropy
Sep 16, 2020 02:47 PM
DeathCougar
Apr 1, 2018 11:29 PM
mussy01
Dec 13, 2016 08:20 PM
TDonkey
Jul 26, 2015 10:14 AM
Hiluxtrucha
Jul 22, 2015 10:00 AM
