still have code 25
Old Dec 18, 2008 | 09:59 PM
lightemup's Avatar
still have code 25
im getting code 25 on my 88 toyota pickup and cant get rid of it ive replaced the o2 sensor. and my truck is bogging really bad in 2nd and 3rd. is there any way to adjust the afm to make it run richer.
Old Dec 18, 2008 | 10:16 PM
abecedarian's Avatar
fix the exhaust leak?
Old Dec 18, 2008 | 10:18 PM
thook's Avatar
Hehehe.....
Or, test the AFM. Fixed is not a bad meter by mere adjustment.
Old Dec 18, 2008 | 10:22 PM
air doth not enter exhaust perchance
breech en requiem for it not be fallacy
Old Dec 18, 2008 | 10:36 PM
thook's Avatar
Ah, but should thine meter be faulty of nature, then thouest may have oxygen in excessivethetheth amount'sth.
Old Dec 18, 2008 | 10:44 PM
perchance thou mayest be vindicated
but exhaust leaks, or even more likely vacuum leaks, are more likely culprits than a mal-adjusted afm.
Old Dec 18, 2008 | 10:51 PM
thook's Avatar
Mal-adjusted doth not a bad meter equal.....
And, possibly it could be a leak. But, I've two meteres go bad on two different vehicles at right around 200k. Both lean conditions. S'why I merely suggest the investigation.
/me pinches abe....XXXXXXX
Old Dec 18, 2008 | 10:57 PM
verity well be things, lest I have 240k on mine without nary a problem.
Old Dec 18, 2008 | 11:04 PM
thook's Avatar
Fortunate thou art, for thine vehicle doth runneth of proper and reliable manners. Salute!
And, $340 later.........so do mine....haha.
Old Dec 19, 2008 | 12:17 AM
lightemup's Avatar
no exhaust leak or vaccume leak. how do i test afm
Old Dec 19, 2008 | 12:38 AM
toyota4x4907's Avatar
http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
edit: Huh. I cant seem to get on 4crawlers website. I dont know if its my computer or what.
Go to 4crawler.com and search around for the AFM testing, if you can get on his site.
Old Dec 19, 2008 | 12:47 AM
hmmm... '88-code 25: air/fuel ratio LEAN malfunction. - feedback value continues at upper limit, or oxygen sensor signal continues at the lower limit.
gonna add the PAIR system may be malfunctioning...
Old Dec 19, 2008 | 12:50 AM
Damn the PAIR system
Old Dec 19, 2008 | 12:53 AM
thought you might get a kick out of that hypothesis.
Old Dec 19, 2008 | 01:06 AM
Naw I dont really hate it. In fact, I think its a good thing.
Old Dec 19, 2008 | 01:33 AM
lightemup's Avatar
k im new this efi stuff so what is the PAIR system how do i test it and hows the weather in freezebanks haha
Old Dec 19, 2008 | 01:47 AM
Oh right on! You're in Palmer I almost moved there last December. Freezebanks is just as the name implies...freezing ha
PAIR= Pulse Air Injection (Reaction ?). Basically it uses vacuum created by the pulsing affect of the exhaust to draw fresh air in to the exhaust to aid the catalytic converter in its processes.
Testing:http://personal.utulsa.edu/~nathan-b...20pulsedse.pdf
Its a 22r/22re, right?
Also, is your air filter really dirty?
Old Dec 19, 2008 | 01:56 AM
lightemup's Avatar
ive never been in fairbanks in the winter only in the summer to race quads. and its 22re, and air filter is brand new out of box. so does PAIR work off egr if doess could you block off the egr and problem sovled or is it a seprate deal
Old Dec 19, 2008 | 02:05 AM
I just moved up here in August. I have been up here in the winter and summer before because my sisters have lived up here (one still does)..but besides the point...
No. it doesn't work off the EGR. I don't think the PAIR will directly affect a code being thrown. Dont take my word for it, but im pretty sure. Like ABE said, its a possible culprit for the lean mixture. How? (what I think) The PAIR valve may be malfunctioning and not allowing air to pass through it, so the O2 sensor is reading extra fuel, therefore causing the ECU to trim the fuel resulting in your lean mixture.
Old Dec 19, 2008 | 02:15 AM
lightemup's Avatar
well it was working fine on the other motor so how much does one cost and do you really need it. well i guess my next truck will be the 22r ive heard they dont have as many problems
