Random no start... What worked for you?
I have had a random no start (just a click) every since I have owned my truck (5 years). From time to time I try to track down the issue and thus far I have not found the answer.
Here is what I have already tried.
Replaced clutch peddle sensor
Replaced Battery & Alternator
Replaced + and - wires from battery
Replaced the main 3 ground wires.
Replaced the wire that runs from + term to starter.
Replaced starter contacts
Nothing has really helped although the new optima battery seemed to make it occur less often.
Seems to be no coloration between a start and no start, and if I unplug the positive side of the battery, wait 3 or 4 minutes and plug it back on the truck will jump to life.
I have left the truck parked for 3 months before and it fired up like new and I have shut off the engine for only 30 seconds and it will refuse to start.
So any more ideas?
So any more ideas?
If you still have the stock starter or a Toyota starter it is more than likely the starter. I had the same problem for years. Just last week I went to the pick and pull to pull one off of an 88 and it starts up perfect every time. The one off of the 88 was a aftermarket non Toyota starter.
I have read that the Toyota starters last quite a while but become troublesome after a few years.
P.S. Order your starter online or find one from the Salvage (make sure they test it first). I never had any luck finding a starter for my truck from the local stores for under $150.
well... waited long enough: this has already been covered by our friend and fellow forum member 4Crawler:
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
check the connections on your battery first. I had that happen a while ago. Didn't look bad but it was enough to make it not want to start. I also had a ground wire fall off that made it so it wouldn't start. but yah check connections before you spend the money.
crashburnoveride
Jul 10, 2015 06:39 AM
madxman21
Jul 9, 2015 10:26 AM
toyoda8488
Jul 5, 2015 10:18 PM
