temp gauge install
Old Dec 20, 2008 | 10:09 AM
86blue4runner's Avatar
temp gauge install
hey guys my buddie bought a new temp gauge and we need to know where to hook it up too,
thanks for the help
Old Dec 20, 2008 | 10:35 AM
chrisbnaz's Avatar
On mine, my thermostat housing had a spot for it on top..From what I've read on here, some don't have it though.
Old Dec 20, 2008 | 10:46 AM
iamsuperbleeder's Avatar
Ha, when you find out a solution, let me know...
https://www.yotatech.com/forums/f116...morrow-158726/
Old Dec 20, 2008 | 11:46 AM
mt_goat's Avatar
What was wrong with this solution? https://www.yotatech.com/50966090-post9.html
That's what I did too, only I made my own:
Old Dec 20, 2008 | 11:49 AM
the probe isn't long enough... it's just barely going to reach to the t-stat housing...
for me anyway... I guess it depends on the manufacturer of the gauge...
mine's not an electronic gauge; if it were electronic, there wouldn't be an issue...
Old Dec 20, 2008 | 12:14 PM
BigBluePile's Avatar
thanks for the help
Are you trying to have two working gauges or just one? If you want to just have one gauge then replace the factoy sender(which is just aft of the thermo housing) with one for the new gauge making sure the thread types are the same.
If you have a thermo housing with the senser on it, that one goes to the ECU so I wouldn't fart with that one.
Old Dec 21, 2008 | 05:20 PM
simpsons721's Avatar
Goat
For your temp probe install in the upper rad hose what kind of sealent did you use to put the probe in it looks white in the pic. Did you have a male pipe end that you taped the metal tube and use adhesive
also what size outside diameter was the pipe and how thick was it
Old Dec 21, 2008 | 06:21 PM
mt_goat's Avatar
Originally Posted by simpsons721
Goat
IIRC it was 1.5" OD pipe, don't know the thickness for sure, looks like maybe 1/8" in the pic. The sealant tube is in the pics (water pump sealant), its gray. The white you see is some teflon tape used between an adapter and probe threads.
Old Dec 21, 2008 | 06:26 PM
CyMoN's Avatar
I removed my block drain plug and installed it there
Old Dec 22, 2008 | 05:07 AM
Cymon
you removed the block drain plug and installed it there
1. What kind of thread is that
-i have sun star gauges with adapters all are npt
2. where is the plug located, can you give me a better idea
thanks
matt
the1998sr5
15
Jul 14, 2020 08:35 PM
gary4runner
Sep 24, 2015 12:53 AM
Nickyodaman
Jul 27, 2015 12:13 AM
Poncho0206
Jul 10, 2015 06:21 PM
