help ID this noise/problem plz
Old Dec 26, 2008 | 06:30 PM
Brendan's Avatar
in 4wd @ highway speeds when i let off the gas pedal i hear a rattle/vibration that sounds similar to the engine but slightly louder and it seems to be coming from around the right front tire or thereabouts. i had a peak at the CV boots and they are not torn but i know that isn't always necessary to indicate a CV problem. i didn't check the u-joints on the drive shaft yet, but that is my next theory. anything else that might be causing this sound? thanks in advance.
Old Dec 26, 2008 | 08:47 PM
iamsuperbleeder's Avatar
U-Joint was my first thought...
how many miles on them that you're aware of? when's the last time you greased them?
for $15 and maybe 30 minutes an end, if you're unsure about their condition, I'd replace them anyway; seen Yotas&Jellos's thread recently with the broken flange?
Oh, and LMAO at your sig; pig and elephant DNA just wont splice, bahahaha, that was a funny episode
Old Dec 26, 2008 | 09:07 PM
thook's Avatar
Um...Brendan, check out this thread....
https://www.yotatech.com/forums/f116...lay-ok-162143/
Be sure to read the write up in the link provided. See if anything with that or the thread itself sounds familiar.
muddpigg's Avatar
I noticed mine makes noise vibration with hubs locked with or with out 4h at highway speed. I'm going to check grease u joints and axle oil, tomorrowish and unlock the hubs since most of the roads a clear now. Possible driveshaft out of balance or damaged, too.
Old Dec 26, 2008 | 09:13 PM
muddpigg's Avatar
Thanks, this helped me.
Old Dec 26, 2008 | 09:14 PM
spindle bushings crossed my mind to, but I think that would be non stop, not jut accur when you let off the throttle...
but I could be wrong...
Old Dec 26, 2008 | 09:16 PM
4runnermt's Avatar
https://www.yotatech.com/forums/f116...27/index3.html
Old Jan 2, 2009 | 10:38 AM
Brendan's Avatar
still not sure what the cause is. i drove around to listen to it some more and it sounds kinda like an engine brake, just not nearly as loud and it only lasts for 2-3 seconds after i let off the gas pedal in 4wd
Esibnitsud
Jul 21, 2015 08:51 AM
str8redneck4life
Jan 2, 2009 09:05 AM
ludefiend
Dec 4, 2008 04:48 AM
ludefiend
Nov 5, 2008 11:49 AM
tcm glx
26
Nov 2, 2008 10:01 AM
