Vacuum hoses and solenoids???
Old May 4, 2011 | 05:41 AM
jvbutter's Avatar
93 runner 3.0l auto.... passenger side wheel well, there is 2 banks of solenoids... one set of 2 and a set of 3. set of 2 is for the 4wd actuator. What is the other 3 bank ( plugs are green orange lt blue) set for??? I need to find a vac diagram for them. Did engine swap. Prev owner didnt have any of these hooked up...
Old May 4, 2011 | 05:43 AM
xxxtreme22r's Avatar
vacuum diagrams should be in the FSM or on the autozone website. Both can be found with minimal effort. It would also help if we knew which engine your going to and from.
Old May 4, 2011 | 06:51 AM
jvbutter's Avatar
FSM????? factory service manual.... thx don't have one, that is why i asked. I will just head back to the library,
pulled a 3.0 and put back in a 3.0
Old May 4, 2011 | 07:02 AM
http://www.ncttora.com/fsm/ save yourself the trip.
Old May 4, 2011 | 07:38 AM
AxleIke's Avatar
Those other 3 are part of the EGR and emissions system.
Old May 5, 2011 | 05:55 AM
jvbutter's Avatar
xxxtreme... thanks for the link....
Axle..... yes i found that yesterday of a diagram... ported vac to the 1st switch then out to the 1 of 2 egrs on the system. Seems like EGR valve.
Now I need to understand how the vac switches work for the front diff... 2 valves actuate the front diff. When 4wd h/l are engaged, only one switch is enabled... and sends vac down to the front switch... the other vac~switch is not enabled thus no vac supplied to the actuator on the side.
Old May 5, 2011 | 06:31 PM
bugs1961's Avatar
Take a look at this thread. In the first post is a picture with all the fittings numbered and in Post #11 each hose is identified as to where it connects at both ends.
https://www.yotatech.com/forums/f116...e-help-209069/
Old May 5, 2011 | 08:21 PM
jvbutter's Avatar
thx Bugs... thats good stuff... XXtreme set me up with a great link.. has same pics as your thread... thx for chiming in... appreciate it
montanatruck
Feb 26, 2017 07:07 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
noosh
Aug 21, 2015 03:49 AM
AppalachianOffRoader
Aug 11, 2015 01:15 PM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
