'90 4runner a/c problem
Old Apr 28, 2011 | 03:35 PM
FishTown's Avatar
I searched a little bit on the subject but didn't find much.
My problem: I bought a 1990 4runner that I knew the a/c didn't work on. The PO gave me a few cans of r12 to have it recharged. After spending a couple weeks finding someone to do this, I finally found someone. They put two of the cans in and my a/c worked great! 4-5 days later it quits on me. When I push the a/c button, there's a weird sound under the hood. I'm thinking it's the compressor. What do y'all think?
Old Apr 28, 2011 | 04:14 PM
runnermedic's Avatar
a/c compressor may be bad but,if the a/c amplifier unit is working ok if something is bad in the a/c system it simply wont engage,low refrigerant ,low or high pressure sensors,well anything.a grinding noise can tell theres a bearing or internal part broken,also check the a/c belt tensioner bearing is not locked.and get a good a/c technician if the low and high pressure ports are original tell the tech to take the time and change the fittings seals too.
good luck.
Old Apr 28, 2011 | 04:21 PM
FishTown's Avatar
A bearing sounds right. I guess I need to find a good technician.
Old Apr 28, 2011 | 04:52 PM
worshipmentor's Avatar
"grinding" might also be a bad compressor clutch. If the lining wears out OR its over charged it will make a weird noise because it cant turn the compressor.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Yota.Jay
Jul 23, 2015 08:08 PM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
