22re vacuum line ?
Old Apr 23, 2011 | 05:25 PM
Bad_Bowtie_ssz71's Avatar
22re vacuum line ?
Ok, just got my 88 4runner back together. Bad HG, got it apart and timing chain was eating up the cover. Fixed every thing and buttoned it all up this evening, except for one vacuum line I cant find. It connects towards the rear driver side of the valve cover. Seems to run fine w/o it but would like to hook it up if possible.
Old Apr 23, 2011 | 05:26 PM
In the pic its the nipple that comes out by the valve cover nut.
Old Apr 23, 2011 | 05:43 PM
worshipmentor's Avatar
Can't really tell much from the pic, sorry! ive got some pics of an 87 22RE and could probably help if i could see it better. can you snap it again?
Old Apr 23, 2011 | 05:56 PM
Ill try to get a better pics tommorow. Took that one with my Iphone.
Old Apr 23, 2011 | 07:07 PM
Buck87's Avatar
Here are some 87 22re vacuum photos. Hope they help.
Looks like the little filter not a hose is missing on the vsv. It also looks like you have the vsv in a different place than mine. I dont know if that is a California thing (see the diagram below).
Old Apr 23, 2011 | 07:43 PM
Buck87's Avatar
Old Apr 23, 2011 | 07:44 PM
Buck87's Avatar
Let me know if you need something else.
Old Apr 23, 2011 | 08:00 PM
Thanck you for the pics! Ill take a better look at mine in the morning and try to get some better pics. Seems like every pic Ive looked at so far has been different
Old Apr 24, 2011 | 08:03 AM
angrybob's Avatar
Something seems off with your current vacuum line configuration. Check it out:
Your original pic (note where the engine removal hook is inn the lower right by the plug wire #4)
Now look at the pic from buck87 and note the same hook:
Now look at the other engine pic from buck87:
Appears that you have the two vacuum bundles mounted in each there's correct location. Mine is just as buck87's is. The green/blue bundle goes just above cylinder #4 by the engine hook and the bundle with the black connector goes btwn plug wire #1 & #2 on the valve cover. Might not be a big deal, but its easy to get it right and may lead you to the problem.
Make sense?
Old Apr 24, 2011 | 01:23 PM
Here's a NON cali truck sticker.
Old Apr 24, 2011 | 02:27 PM
Ok thancks guys, It seems like Im just missing the black breather cap(?) and not actually a vacuum line. We put everything back like it was before the HG repair, so the Previous owner must have moved things around a little bit. According to the receipts I got with the truck, the PO, had the motor rebuilt at 100K. So they shop that built it probaly just stuck stuff wherever they could.
Old Apr 24, 2011 | 04:57 PM
OH YEAH!!!! it just hit me after messing with mine this after noon! what you are missing is the filteroff the VSV. I am not sure if it is a one way restricter too or not but it is absolutely a filter. Check out this test procedure for the VSV and it shows it.
File Type: pdf
Old Apr 25, 2011 | 04:26 AM
RustBucket's Avatar
That VSV with the two vac lines in parallel is for the idle-up for AC and power steering. The blue one that often sits near the rear of the valve cover is for the fuel pressure regulator hot-start condition. Conventional YT wisdom says this one is unnecessary.
Old Jun 15, 2011 | 12:03 AM
MortonPhotographic's Avatar
Thanks for the info and diagram stickers!
smthwsn357
May 1, 2024 07:28 AM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
jgwerth
Jul 16, 2015 03:23 PM
TokyoD23
Jul 12, 2015 06:01 AM
