idler arm noise!
Old May 1, 2011 | 10:13 AM
808-3VZE's Avatar
idler arm noise!
Howzit from da 808 state! My 94 pickup has a real loud noise coming from the idler arm and when u shake it its real loose!
Old May 1, 2011 | 10:27 AM
xxxtreme22r's Avatar
replace it. bushings are bad most likely. Autozone FA5040 is the arm you want.
Old May 1, 2011 | 10:31 AM
James Woods's Avatar
Yep X2, brakes and steering are just two things that I feel must be kept up and not boogered together.
Old May 1, 2011 | 10:33 AM
95blackToy's Avatar
just replace the idler arm. its like 4 bolts.
Old May 1, 2011 | 11:14 AM
and don't let the idiots at AZ tell you the FA5040 arm won't fit your truck. I wanna say the 94 will show it as stock though but just in case it doesn't, the FA5040 is a direct swap. When asked vehicle info just tell them you want the FA5040.
Old May 1, 2011 | 09:52 PM
808-3VZE's Avatar
Rajah! I just changed it bout a hour ago. All I can say is that was one messed up oem idler arm! All the bushing were gone and the arm was extremely loose! Replaced it with a Napa Master ride chassis one. Steering is way better and no noise!
Last edited by waskillywabbit; May 2, 2011 at 04:31 AM. Reason: Inappropriate language
Old May 2, 2011 | 05:28 AM
The best aftermarket idler arm out there is the AZ FA5040. It really the only arm that SDORI makes their bronze bushings for. Glad ya got it fixed though.
Old May 2, 2011 | 05:59 AM
808-3VZE's Avatar
We don't have a Autozone in HAWAII! I wish we did. Also I work for Napa as counterman. I got a 85 Toyota straight axle waiting to do a sas swap. Glad that got good bros like you that help people like me! Mahalos again!
Old May 2, 2011 | 06:02 AM
Mahalo, ya know I spent 5 years out there and forgot there was no AZ. to me hahaha.
Old May 2, 2011 | 09:27 AM
808-3VZE's Avatar
What island were you on? I'm on Oahu. Toyota 4x4s here are unreal everybody wants one! I@ looking for another truck too 84-85 xcab.
Old May 7, 2011 | 11:35 PM
FlynHaYin's Avatar
Just replaced mine too. Still got front end problems tho.
Old May 8, 2011 | 02:48 AM
Rod.s's Avatar
I just replaced the bushings and seal in my 94 pickup. Bought the replacement bushings and seal from my Toyota dealer. Fairly simple job, there is a link on one of these sites that takes you through the step by step process. I can find it for you if you like. Replacement parts cost $28.
jashoeuh
Nov 18, 2024 08:08 AM
norcal98
Aug 10, 2015 06:20 AM
razorman8669
Jul 12, 2015 12:13 PM
ptb12
Jul 5, 2015 01:49 PM
