W56 output shaft in an R150f...possible?
Old Apr 28, 2011 | 11:45 AM
RBX's Avatar
RBX
I am about to aquire an R150f to swap out my A/T. I have a W56 with the attached RF1A t-case, the W56 needs a rebuild, and won't mate to the 3VZe anyhow.
I would like to get the gear driven RF1A transfer case mated to the R150 using an adapter, that part is easy.
HOWEVER, i understand that the W series output shafts are 21 spline and the R series are 23 spline. so to make this work i would need an additional $140 output shaft from a vender.
Is it possible to take the output shaft from the W56, and install it in the R150 to save a few bucks?
Any one try this?
Thanks
Old Apr 28, 2011 | 12:32 PM
MSR's Avatar
MSR
no that is not possible however if you want you can cut the different couplers and weld them together not suggested though.
Old Apr 28, 2011 | 12:37 PM
RMA's Avatar
RMA
inchworm has a 23 to 21 coupler .. if im understanding you correctly.
kawazx636
Oct 6, 2021 03:03 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
toyotasaurus
Sep 24, 2015 03:30 PM
