Main Ground Fell Off, Blue VSV, and AFM questions
Old 05-03-2011, 05:10 AM
Rustycan's Avatar
Exclamation Main Ground Fell Off, Blue VSV, and AFM questions
I was off roading and my main ground fell off, the truck is a 22re 1988 4x4 and now the truck wont start, it cranks and cranks but nothing. I rebolted the ground back to the frame, and im getting no injector pulse, what do you guys think?
Old 05-03-2011, 05:14 AM
Lizardcrunch's Avatar
check some fuses voltmeter some circuits fuel pump clicks on or no?
Old 05-03-2011, 05:17 AM
Rustycan's Avatar
I checked all my fuses, and im pretty sure the fuel pump does click because i listen for it. i will double check when i get home, but also do you think i fried my ecu or anything? i got no check engine light and everything on the truck still works it just wont start. Cranks and cranks and cranks til the battery dies but nothing
Old 05-03-2011, 05:20 AM
Im guessing its a 22re?
Old 05-03-2011, 05:23 AM
Rustycan's Avatar
Yeah its a 22re, five speed 4x4, great truck just need to figure this out and i didnt know if there was a most likely culprit
Old 05-03-2011, 05:44 AM
Sorry i don't cant help not even sure how that motor works without a crankshaft position sensor hopefully someone else will know
guess go through the list
heres a flowchart that may help
http://ifitjams.com/starting.htm#starting%200
Old 05-03-2011, 05:58 AM
Rustycan's Avatar
OK thanks for your help man, i will keep this post updated as i go
Old 05-03-2011, 06:34 AM
tlrskunk's Avatar
Check your main Coil wire to the Distributor. Mine fell off on Sunday and was under my rubber boot over the distributor and I check everything but that for 15-20 minutes put it back on and it fired right up.
Old 05-04-2011, 10:14 AM
Rustycan's Avatar
Exclamation **22re AFM question
Basically im at the point on my truck to where i think it could be the AFM. The truck cranks and cranks and cranks but never fires. Hot Spark plenty of fuel, and basically its flooding itself out. The AFM clicks wierd when its trying to start, and when i have a friend hit on it it almost wants to fire. Do you guys think i am going in the right direction with this? It seems like the AFM is just making it want to flood out. any input would be great!
Old 05-04-2011, 10:49 AM
trdwssrs's Avatar
did you check your EFI fuse?
Old 05-04-2011, 12:53 PM
Rustycan's Avatar
Where is the EFI fuse located?
Old 05-04-2011, 01:07 PM
Rustycan's Avatar
All the wires are connected, its just flooding out now
Old 05-04-2011, 01:51 PM
FleshThorn's Avatar
As you stand of the passenger side of the vehicle looking at the engine compartment fuse block, the top- left 15 AMP fuse.
Old 05-04-2011, 02:32 PM
Junkers88's Avatar
May sound strange getting advice from me since mine is dead as well but are you sure you have spark?
Old 05-04-2011, 03:54 PM
wyoming9's Avatar
Red face
Just why did your ground wire fall off and how did you fix it??
When this does not start quit cranking and find out what your problem is.
I am thinking your problem is another bad ground some place.
Old 05-05-2011, 05:05 AM
Rustycan's Avatar
The ground came off because i think it wasnt tight. I have looked at all my grounds and looked for anything loose. My friend who is a 22r guy also looked it over as well. We came up with the possiblity that it could be the air flow meter because it is flooding itself out before it can start. Anyone agreee?
Old 05-05-2011, 05:12 AM
Rustycan's Avatar
Yeah all fuses are good.
Old 05-05-2011, 06:38 AM
shaeff's Avatar
You said there's no injector pulse. How is it flooding if the injectors aren't opening?
If you're getting injector pulse, that means they're opening. If the fuel pump runs, then they're getting fuel. As long as your air filter isn't 100% clogged, you're getting air, the last thing you need is spark and timing. Timing isn't a likely culprit out of the blue like that, especially on the 22re with a timing chain, so I'd go with spark. Pull a plug and check for spark while cranking.
No spark? Check the dizzy, coil, coil wire, plug wires, etc... Pull the cap off and verify that the rotor isn't all burned out and the contacts in the cap. If you have spark, fuel, and air, the truck should start.
By the way, how'd you come to the conclusion earlier that you had no injector pulse? Grab a noid light and remove all doubt.
Old 05-05-2011, 08:28 AM
Rustycan's Avatar
Basically the shop i took it too was pretty stupid because i couldnt work on it during all the storms i had. Im pretty sure they couldnt figure anything out so they just told me the computer needed replaced. I took off the fuel line at the filter and it shoots out fuel. When you crank it the plugs just get flooded with gas. I have since been told by 2 22r guys it could possibly be my AFM. The truck wants to start it just cant. The truck has a new distributor, rotor, cap, wires, and plugs.
Old 05-05-2011, 10:14 AM
misaaccooper's Avatar
Are you sure it is getting fuel. Make sure the pump is coming on by having someone feel the fuel line at the tank. Unless your spark plugs smell like gas. EFI fuse is 15amps and is the bottom left fuse (note spares fuses immediate left) at the box under the driver kick panel.
Quick Reply: Main Ground Fell Off, Blue VSV, and AFM questions
