4" bracket lift need measurements
Old Apr 28, 2011 | 02:30 PM
Cyberman's Avatar
I have a 91 extended cab that I had put a Rough Country lift on with the original springs. I just recently picked up a set of "lift" springs that a guy had pulled off a truck years ago. These springs are the same length as the originals, but have 4 leads plus an overload, instead of 3.
I put the springs on, and took the blocks out. Looks like I lost 2" of lift.
Could someone with a similar lift and 33s measure the distance from the ground to the top of the wheel well (front/rear).
Thanks
Old Apr 28, 2011 | 03:05 PM
Stuwy123's Avatar
Put your blocks back in and problem solved.
It all depends on how much rake you want (negative or positive). Baja or hotrod style. Like \, or like / or -.
Old Apr 28, 2011 | 03:54 PM
Cyberman's Avatar
Um ya, forget I asked the question.
Old Apr 28, 2011 | 04:12 PM
rattlewagon's Avatar
You could combine the 2 packs, see where that gets ya.
Old Apr 28, 2011 | 07:45 PM
peow130's Avatar
I'd say just put the blocks back in. As long as they're not aluminum, you'll be fine.
Old Apr 29, 2011 | 02:49 AM
Cyberman's Avatar
The title of my post says "Need Measurements", not "Need Opinions", or "Need Options". I know my options, and I have my own opinion. I was merely explaining my situation to try to explain why I wanted the measurements.
If no one out there has a similar lift with similar tires that can't run out and take a two measurements, then forget I asked the question.
Old May 3, 2011 | 03:52 PM
btu44's Avatar
Long time lurker here with a 89 Xtra cab similar to yours.
I bought the truck with the lift already installed but w/o any history about any other mods.
I'll describe what I have so you can decide if it's any help.
Rear (unloaded) - 31" tire dia., 3 'stock looking' leaf springs, 1 arc'd leaf (no plastic buttons at end), 1 bottom out spring, shackles look aftermarket (5.5" bolt centers).
Ground to wheel well = 47" or 5.75" of bump stop clearance.
Front - looks to be stock torsion springs and no extra weight of a wench. I don't know if the spring preloaded is correct, but the front 'sags' 2.2" from fully topped out to under weight.
Ground to wheel well 43" (at wheel well center 'lump w/ bolt) or 2" of bump stop clearance.
Old May 3, 2011 | 04:34 PM
Cyberman's Avatar
Thanks for the reply. Not quite the same setup, but the kind of information I'm looking for.
Old May 3, 2011 | 04:47 PM
xxxtreme22r's Avatar
Cyberman in my build thread, not sure which page but maybe 7 or 8 pages from the end I have my measurements from the ground to the middle of the spring hanger bolt where your actually supposed to measure lift height. Anyway, I gained 3" total between factory worn out springs and a 31 to 33 tire size change.
Like You, I don't know who made my springs, but they were supposed to be either 2" or 3" lift springs, but I really think mine are a factory leaf pack with a long AAL in there, but cannot say for sure. Also on top of that I have 6" hole to hole shackles.
foampile
Dec 18, 2022 01:29 PM
nvdesertrunner
May 11, 2020 08:18 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
coffey50
Jul 28, 2015 10:55 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
