1994 22RE Won't Start. Need Help.
Old May 9, 2011 | 05:01 AM
dustybottoms's Avatar
Hi, I'm new to the forum. I've had my truck for around 6 years now and have never had a problem with it starting.
I ordered a new matched complete set of injectors from injectorwarehouse and installed them this weekend. While I installed them I replaced all of the vacuum hoses one by one.
I went to start the truck after the install and it was running terribly rough. Long story short I had 2 of the injector harness connectors mixed up. According to my Manual.
Now the truck won't run even a little bit.
The fuel rail is pressurized.
It is getting spark.
I connected an old injector to harness while cranking the engine and it was "clicking" so I know they are getting a signal.
After cranking awhile the plugs were wet with gas.
I checked the TPS, Open Circuit Relay, all fuses, and Air flow sensor. I'm not a complete novice mechanic, but I am completely stumped.
Any ideas or help at all would be greatly appreciated!
Thanks!
Old May 9, 2011 | 04:37 PM
I just triple checked all of my vacuum hoses, all good.
I am getting 12V to the injectors with the key on.
I sprayed some starter fluid in the intake and not even a hint of it starting.
I e-mailed injectorwarehouse to see if maybe I got a batch of bad injectors?
I don't really know what else to check.
Oh and I made sure the knock sensor was plugged in, thought it might give me some timing issues if it was overlooked.
sandyota
Feb 4, 2021 11:16 AM
Doug4320
Mar 24, 2018 10:11 PM
Road Bull
Oct 10, 2015 04:55 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
bryan34w
Jul 6, 2015 05:53 PM
