Swapping back from a Weber to the stock carb
Old May 6, 2011 | 06:01 AM
sinteger's Avatar
hey folks, I was just wondering if anyone had advice on running this motor with the stock carb with the egr and other vacuum systems removed. i'm having trouble with my 32/36... vacuum leak, i think its the carb body itself. anyways the point is i want to temporarily have the truck running right, but i took the egr system off and tossed it as well as all the vacuum and air pump stuff. the only vacuum i have hooked up is the spark advance.
all that being said, could i just put the stock carb back on and cap off it's vacuum ports (other than the advance) and be ok?
Old May 6, 2011 | 06:13 AM
SCToy's Avatar
To be honest I don't know the answer to your question.
Not sure your location, but if you're in CA and need to smog than I am guessing you'll have to hook it all back up or maybe take some white out to the emissions info under the hood (kidding).
vasinvictor
Jan 20, 2016 12:39 PM
ZXT
Sep 1, 2015 09:23 AM
Chili327
Jul 11, 2015 10:27 PM
kazuya2416
Jun 27, 2015 12:24 PM
saphirekosmos
Jun 22, 2015 10:26 AM
