timing chain replacement foul up
Old May 2, 2011 | 07:40 PM
Ant954's Avatar
Talking timing chain replacement foul up
So i installed new cam, oil pump, water pump, head gasket, and adding electric fan. So get all the parts on and buttoned back up do a test start. All was fine until i walked around to check engine andit was spewing oil. Looks to be from between timing cover and engine case or form oil pan gasket. Cant tell yet had noone at the garage with me. So off to start again in the morning its like sex with no orgasm
Old May 2, 2011 | 08:16 PM
Ant954's Avatar
permatex?
So instead of going to get a new gasket i am thinkin of just using permatex grey or something to try to make a gasket whats some thoughts on that?
Old May 2, 2011 | 08:24 PM
toyospearo's Avatar
no, I wouldn't do that. Take the time and do it right. Get the gasket and apply a thin layer of RTV Black on the block and then put the gasket on and button it up.
Did you check to see if it is your main front crank seal??
Old May 2, 2011 | 08:30 PM
Ant954's Avatar
not the front seal, its coming out under the ac compressor. I know Subaru doesnt use bolts in some of there engines and the blocks are insane to tear apart thats what got me thinkin. Hopefully somehwere close has it in stock, its my dd right now
Old May 3, 2011 | 02:30 PM
stackedyoda's Avatar
I used ultra copper on everything when I did my timing chain/head gasket, especially around the oil pan and no leaks.
Old May 3, 2011 | 02:31 PM
Ant954's Avatar
found problem
I found the problem on the new timing chain cover there is a small cutout right beside the passage that carries oil from the pump and its to hold permatex. Just did the second time and is holding oil
fasterspider
Oct 6, 2015 10:24 AM
Ichneumon
Sep 27, 2015 04:21 PM
Badger62811
Jun 26, 2015 09:26 PM
Taz22R
Jun 21, 2015 04:44 PM
paxanders
Jun 21, 2015 06:29 AM
