90-95 (auto) speedo gears all interchangeable?
Old May 6, 2011 | 03:08 PM
The MAN's Avatar
I just regeared from 4.3 to 4.1, so obviously my speedometer is 2mph off. What I do know is, I have a 20 teeth speedometer gear and I will need a 19 teeth one to match my axle ratio and tires.
I looked through the parts catalog and see that the VZN85 uses a 19 teeth speedo gear. Does this fit on all the other runners (that has an automatic) of the same era regardless of engine?
I thought about using a 18 teeth also, but that'll make the speedo slightly fast. I don't want that!
Anyhow, if the speedo gears in the 90-95 mini truck/runners mix and match, does anyone know where I can find these cheap (other than junk yard or dealer)? I would love to have an accurate speedometer again
Old May 6, 2011 | 03:12 PM
justin_4runner's Avatar
i was looking at cheaptoyotaparts.com one time and found where u can order each one depending on what u needed. just an idea,
Old May 6, 2011 | 03:18 PM
The MAN's Avatar
well their site is broken... but I do prefer to get a used gear to try this if possible
what I still need to know though is if they are all interchangeable between the 2nd gens... no point spending money on something that won't work
Old May 6, 2011 | 03:22 PM
RMA's Avatar
RMA
"I looked through the parts catalog and see that the VZN85 uses a 19 teeth speedo gear"
just curios man .. what parts catalog are you looking thru for this info, you found
Old May 6, 2011 | 03:23 PM
The MAN's Avatar
the toyota epc
Old May 6, 2011 | 03:28 PM
sebastianholmes's Avatar
honestly? 2mph? thats not even enough to hardly notice.
Old May 6, 2011 | 03:30 PM
The MAN's Avatar
it's called being OCD
your opinion aside, can I please know about the speedo gears?
Dieselmann
Feb 19, 2019 02:57 AM
deepmarsh
Aug 6, 2015 03:44 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
HRDC0R19
Jul 5, 2015 06:43 PM
