Steering column electrical issue
Old Apr 26, 2011 | 07:31 AM
Clifford91's Avatar
Hey everyone,
My 92 pickup has this kind of wierd issue (surprise, surprise) The "Fast" setting on my windshield wipers, the Windshield washer fluid motors, and my horn, will only work of the column is tilted all the way down. If that doesn't sound like one of those "Toyota" things, I don't know what is.
What do i do about it? I haven't actually gone under there and really checked stuff out. It seems like there's a loose connection or contact point somewhere in there, but I dunno what would affect all three of those things. This happened to anyone before?
Thanks,
Andrew
Old Apr 27, 2011 | 08:44 AM
Swim's Avatar
I'd pull the wheel off and check it out. You should be able to get access to them with the wheel removed.
Old Apr 29, 2011 | 08:53 AM
VegasNaturist's Avatar
Originally Posted by Clifford91
Hey everyone,
Thanks,
Andrew
There are 4 screws on the underside of the column cover. remove these screws and it will give you access to the combo switch wiring. Sounds like a harness connector is pulled too tight, loosing connection when you tilt up, and barely making connection otherwise.
jasonty
41
Dec 23, 2018 01:00 PM
coryc85
Sep 9, 2015 06:24 AM
v_man
Jul 23, 2015 04:01 PM
Poncho0206
Jul 10, 2015 06:21 PM
AaronM
Jul 8, 2015 07:15 PM
