New trail gear rear disco
Old May 6, 2011 | 03:19 PM
sebastianholmes's Avatar
I was surfin around pirate and look what i found!!!! this is gonna be so freakin sweet, front end digs without an atlas! I cant wait to see the cost. It runs on air and if you go through the pirate thread it is stated that an ARB compressor can run it or even a small air tank. I know im pumped about it and it would go sick with an SAS and dual cases. just figured I would share it with you guys
Originally Posted by Max Volume
Old May 6, 2011 | 03:31 PM
Junkers88's Avatar
I'd think running a twin stick on a stock t-case would be easier and do the same thing. Looks cool though.
Old May 6, 2011 | 03:34 PM
Twin sticks only give you rear wheel drive though. this gives you front wheel drive so you can use the front tires to turn in a VERY small radius while the back tires keep you still
Old May 6, 2011 | 03:35 PM
The MAN's Avatar
shiny
not to mention with this you could flat tow without dropping the drive shaft!
Old May 6, 2011 | 03:45 PM
Junkers88's Avatar
Not true (I think). Twins gives you the option of either front or rear drive, front or rear low/high. One stick activates the front the other activates the rear.... unless I'm confused on that.
I think its- one stick gives you front high/neutral/low and the other gives you rear high/neutral/low.
Old May 6, 2011 | 03:49 PM
nahhh, with twin sticks one stick controls the high/neutral/low and the other one controls the 2wd/4wd. they allow you to have a 2 low instead of only 4 low. to my knowledge the only transfer cases that behaves like you said is an Atlas. if twin sticks did that then this would be 100% useless.
Old May 6, 2011 | 03:54 PM
Junkers88's Avatar
Thanks for the clarification. Learn something every day right!
Old May 6, 2011 | 04:00 PM
corax's Avatar
Yep, on the stock t-case or even duals, the rear is always turning since there would be no reason to disconnect it - twin sticks just let you control 4WD and Hi-Low separately so you can do 2LO if you want (which you can do by unlocking the front hubs anyway)
Old May 6, 2011 | 04:02 PM
but who wants to get out and unlock the hubs every time you want 2 low??? lol
Jun 1, 2021 01:51 PM
XtraCab
Apr 12, 2020 05:25 AM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
