Summit Hot Shot or DIY starter button (89 22re)
Old 05-05-2011, 10:09 AM
Junkers88's Avatar
Isolated the issues with my rig, the usual start sometimes and sometimes not, and determined it's the ignition switch. Yes I know lots of folks have this problem. Well if I can't source a new one (or can afford it) I'll need to either get the Summit Hot Shot (like this since it's designed to fix this issue) or build myself a starter button (probably cheaper than Summit).
Since I know nothing about either I'd like your opinions on both, if you have/had either, pros/cons, etc.
Oh and if any of you have a darn link on how to make your own starter thing please share it and keep in mind that I'm an electrical idiot.
Old 05-05-2011, 10:14 AM
waskillywabbit's Avatar
Try DeathKitten
:wabbit2:
Old 05-05-2011, 10:16 AM
xxxtreme22r's Avatar
You mean ignition switch or starter relay? When I thought mine went bad (starter relay), I almost switched my relay over to an older Ford style relay.
Old 05-05-2011, 10:25 AM
Junkers88's Avatar
deathkitten?
I'm 99% positive it's the ignition switch. I pulled it apart and the copper contact (the big rings) are all pitted and in pretty poor shape.
I called NAPA and they have a replacement for 91$. Crap this is getting expensive in a hurry.
Old 05-05-2011, 10:30 AM
91 what????
http://www.autozone.com/autozone/par...ier=66023_0_0_ $55.99
Rock auto is showing 3 one for $40 one for $63 and one for $66
Old 05-05-2011, 01:38 PM
Junkers88's Avatar
Originally Posted by xxxtreme22r
91 what????
Thanks for the heads up on that! I ran to Auto Zone and got one for 44$. *whew* Nothing like saving 50 bucks that I can use elsewhere.
So the new switch is in and it starts like it should. Now this brings up a new question.
Should I still install the HS or DIY button to help prolong the life of the ignition switch?
Old 05-05-2011, 02:08 PM
Hadmatt54's Avatar
By adding more connections in that circuit you add more places that something could go wrong. For example this latest problem could be narrowed down to wiring, start relay, ignition switch or starter. If you add a push button you've added three more failure points. The push button or the wiring connections on each side.
Your truck is an 89, the factory ignition switch lasted 22 years. If you consider the possible number of times that switch was turned to the start position in those 22 years....most anyone would call that pretty good service.
If it was mine I leave it the way it is!
Old 05-06-2011, 01:14 PM
BigBluePile's Avatar
Leave it alone
Old 05-06-2011, 01:25 PM
Junkers88's Avatar
Leave it alone
Thanks guys. I'll stick with the old "if it ain't broke don't fix it" and leave it alone. If it goes out again in about 2031 I'll figure something out then.
Old 05-06-2011, 01:56 PM
Yeah...I doubt the local auto store special will last that long....
Old 05-06-2011, 02:58 PM
kiyobrown's Avatar
Leave it alone
Really? Logan tinkers on his rig more then a meth addict.......
Pretty sure your 31's and 4.10's weren't broke.........
Old 05-06-2011, 03:14 PM
Junkers88's Avatar
Yeah! Take that Logan!!!
Old 05-09-2011, 10:21 AM
How's that AFM adjustment going for ya? Ass.
Old 05-09-2011, 12:05 PM
kiyobrown's Avatar
Are we just now getting to this?
Old news, try to keep up, old timer.
Old 05-09-2011, 12:49 PM
holy cow what did I start by sending him to AZ for an ignition switch. haha. Sorry man.
Old 05-09-2011, 01:02 PM
You just dont want my Truetrac......
Old 05-09-2011, 03:43 PM
kiyobrown's Avatar
I'd like an LSD more then an Aussie for the rear diff. Just need it in working order........
Old 05-11-2011, 11:18 AM
Gawd....it works just fine....
Old 05-11-2011, 11:28 AM
Junkers88's Avatar
I think Kiyo is worried that once he goes locked/locked he'll start wheeling more.... :wabbit:
Edit: OMG Logan I just looked at your avatar again and realized it was a pile of Big Blue!!! ROFLMAO!!!!
Old 05-11-2011, 11:34 AM
4Crawler's Avatar
I used the Painless Hot Shot relay kit and it works fine:
-http://www.4crawler.com/4x4/CheapTricks/Starter.shtml#OtherOptions
Sure, you can do it yourself for less (switch + relay), but the kit is nice. All pre-wired, socket and bracket for relay and switch, includes circuit breaker and pretty much plugs right in. Totally solved my random no-start issue (and the starter contacts and wiring on mine is fine). Big advantage of the relay setup is you are now passing 0.1 amps through the ignition switch while starting, instead of ~20 amps for the starter solenoid.
Quick Reply: Summit Hot Shot or DIY starter button (89 22re)
