New header....now vibrations.
Old May 6, 2011 | 06:41 PM
RogueYota's Avatar
I didnt find anything for it so I made a thread.
I just installed a new hooker header. I noticed that the truck vibrates now. The header is a VERY tight fit. Misses the bell housing by about a half inch and torsion bar mount thingy by less than that. I noticed that the torsion bar mount thingy's heat sheild was touching the header so I took it off. IDK if that was cause the vibration....but I can feel is in the entire cab. I havent started it with the sheild off but I dont think that will make a difference. Any input would be nice.
Old May 6, 2011 | 06:49 PM
The MAN's Avatar
do you still have a flex pipe? what are the condition of the exhaust hangers?
Old May 6, 2011 | 06:51 PM
RogueYota's Avatar
No flex pipe...never had one. It never did this with the stock manifold. or the header I had before. The entire exhaust is all new.
Old May 6, 2011 | 07:08 PM
The MAN's Avatar
well if you don't have rubber exhaust hangers or they're in bad shape, they can cause vibrations... just weird that it's doing it now and not before... probably something to do with harmonics. Might want to look into a flex pipe too
Old May 6, 2011 | 07:12 PM
RogueYota's Avatar
What do you mean by harmonics?
Old May 6, 2011 | 08:37 PM
James Woods's Avatar
You say that it gets close to the torsion bar mount, is it possible that when the engine is running that it is rattling against the mount? When the engine is running it is going to move some, take a look at where it gets close and make sure those areas are not getting shiny from contact.
Old May 7, 2011 | 11:37 AM
RogueYota's Avatar
I did... I removed the shield and it stopped. But now when I turn right I can feel it...most likely because I am turning right thus making everything on that side move closer....so ill break out the grinder
taco_ted
Oct 24, 2015 11:49 AM
jennygirl
Apr 23, 2015 11:53 AM
smithe213
Apr 9, 2015 09:03 PM
jasco
Jul 16, 2007 07:03 PM
BBA
Nov 9, 2005 02:52 PM
