3.0 no spark? help
Old Aug 12, 2007 | 09:04 AM
saleen9973's Avatar
3.0 no spark? help
Hey guys i have a 94 4 runner i just did the hg and now it wont start. I checked for 12 volts at the coil and it has it, i ohm tested the coil and it is in spec. i tried 3 different coils and ignitors and no spark, i changed the dist and still no spark. i put in a new toyota efi relay and checked all fuses and all is good. Please give me some more ideas to try before i burn this thing to the ground. HELP HELP.
Old Aug 12, 2007 | 05:18 PM
saleen9973's Avatar
no one here can help me? please help.
Old Aug 12, 2007 | 05:29 PM
justinking060310's Avatar
Are you positive that you don't have spark? Tell us how you tested it --
I am thinking that its just cranking over and not firing?
- Spark Plug Gap
- Wires (use ohm meter to test resistance as per FSM)
- Do you have all your air cleaner stuff hooked up?
- AFM?
- Are you positive that you have fuel?
- Did you put the rotor in? don't laugh, i have seen it
- Test coil?
Just trying to start at the bottom - if you are positive that spark is the problem, there are only a few things in the circuit, and you have touched on all of them.
Katie
Old Aug 12, 2007 | 06:16 PM
saleen9973's Avatar
i ohm tested the coil wire and it came back fine. All the air cleaner stuff was hooked up and tight. I am sure i have fuel i pulled the line off and fuel came out. The rotor is on. I have 12 volts at the coil, but when i crank it the volts go down to about 10. If i had the timing belt off a tooth would i still get spark? If i have a bad afm would i still get spark? What i dont get is i have 12 volts to the coil and when i crank it i get nothing from the coil wire, i grounded the coil wire and cranked it and nothing. I even tried turning the dist 180 out to see if that was the problem and still the same problem.
Old Aug 14, 2007 | 01:57 PM
saleen9973's Avatar
no one else has had this problem? I checked the dist and it came back with in specs, the coil is getting 12 volts if the afm is bad will i get spark?
Old Aug 14, 2007 | 08:09 PM
Guardian_Saint's Avatar
it just won't start?
Old Aug 14, 2007 | 08:23 PM
seanz0rz's Avatar
Guest
ground wire maybe?
Old Aug 14, 2007 | 08:38 PM
dcg9381's Avatar
Check for signal generation out of the distributor.
Old Aug 15, 2007 | 10:11 AM
saleen9973's Avatar
i will check for signal out of the dist. i did ohm test the dist and it was in specs. If the afm is no good will i get spark?
Old Aug 15, 2007 | 11:39 AM
saleen9973's Avatar
i just checked the afm and when i have the key on and open the flap to fuel pump comes on. then i ohm checked it and it was no in spec. can this be my problem? when i did my hg i placed a maganetic tray on the afm do you think this could have messed it up?
Charecter1
Nov 6, 2023 10:08 AM
wafoogalla
Nov 2, 2016 11:02 AM
old87yota
Oct 25, 2015 02:15 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
tobylab
Jul 12, 2015 12:53 PM
