Airbox mod for 22RE
Old Aug 15, 2007 | 10:03 AM
starrett's Avatar
Airbox mod for 22RE
Has anyone out there modified/drilled-out the 22RE airbox? I've read the Tech Write-up "Deck-plate mod for the 3rd gen 3.4V6" and "Airbox mod for the 3.0V6" but wondered if these mods work on the 2nd gen 22RE???
Old Aug 15, 2007 | 10:44 AM
Jay351's Avatar
isnt the airbox on the 22re the same as on the 3vze?
Old Aug 15, 2007 | 10:57 AM
starrett's Avatar
The 22RE airbox appears different than what's shown in the Airbox Mod Write-Up for the 3.0. I haven't actually seen a 3vze airbox.
Old Aug 15, 2007 | 11:35 AM
norcalsvx's Avatar
i drilled some holes in mine (it was a little louder but no HP gains) i went with the downey intake and it seems to have added some power
Old Aug 15, 2007 | 12:13 PM
thook's Avatar
The airbox on the 22re is different in shape. It's rectangular while the 3vze box is circular.
The deckplate mod doesn't apply to the 22re because they have a different air flow metering device and set-up. The drilling out of the air box won't do anything for the 22re except to dirty your air filter faster. Check out the intake/battery swap for the 22re. That would be about the only thing that will do what I'm guessing you want. Even then, it doesn't do a whole lot by itself.
https://www.yotatech.com/forums/f116...y-swap-111508/
Old Aug 15, 2007 | 12:48 PM
starrett's Avatar
That's what I figured. Seems like a lot of work for not much reward. Thanks all.
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
Massmayhem247
Jul 18, 2015 05:46 AM
icentropy
Jul 11, 2015 07:21 AM
Nickdigg
Jul 7, 2015 06:04 AM
