w56 tranny with a chevy 350 motor
Old Aug 18, 2007 | 07:47 AM
weakyota91's Avatar
I need your guys opinon. I have a friend who is doing a chevy 350 swap in his 91 runner and is trying to decide what tranny to go with. what would be more reliable and from your experiences whats better.
Toyota 5 speed w56 or a chevy turbo 350 automatic. Thanks guys move this if necessaryt sorry if its in wrong spot
Old Aug 18, 2007 | 07:53 AM
gilby4runner's Avatar
if possible i would go with the 350 turbo. Great transmission!! I am afraid that the added HP and torque would not fair to well in the long run with the yota transmission
Old Aug 18, 2007 | 10:53 AM
InternetRoadkill's Avatar
If that 350 is built up, I'd consider moving to the turbo 400.
Old Aug 18, 2007 | 11:27 AM
Yoda's Avatar
Why not go with a 4 speed OD trans? (700R4?)
Old Aug 18, 2007 | 11:34 AM
Jay351's Avatar
v6 5spd could handle the power of a 350 (r-150/r-150f)
Old Aug 18, 2007 | 10:24 PM
Bear80's Avatar
A lose rule of thumb:
The w56/58 can take under the 300 lb/ft torque range. The R150f is the way to go if you can, still I would not rate it sizeably more for torque handling.
Turbo 400 is the winner, but again between the w56 or turbo 350, I'd go 350.
Old Jan 12, 2008 | 10:09 PM
KPEARSON's Avatar
hay
i have a chevy 350 with dual quads 750s and a turbo 350 and it seem to be great but axles is the issue i need help to find out what axle can take the power?
Old Jan 12, 2008 | 11:36 PM
notanymore's Avatar
not that the w56 is a bad or weak tranny, but your talking about alot of power and torque that that tranny just isnt meant for, the turbo 350 would be a better choice.
Old Jan 13, 2008 | 05:07 PM
bigarms23's Avatar
you can use the w56 trans have marlin rebuild it and have him turn it into a w56hd trans
Old Jan 13, 2008 | 05:15 PM
TORTIS's Avatar
350 or 400 trans.
Old Jan 13, 2008 | 05:20 PM
GenXr's Avatar
TH350/400, 700R4 are all good suggestions.
Have you checked out Downey-offroad.com? They have a large conversion chart, with adapters and their recommendations. They do not recommend the W56 with a chevy 350cid engine. The V8 has too much torque for it.
Old Jan 13, 2008 | 05:32 PM
TRD_JW's Avatar
personally i went with the 262 or 4.3 conversion to my r-150f great choice plenty of power im runnin fac gears 33's and a 4.3 and all i can say is good bye Z71's great low end and runs cooler
i guy around here did the swap into his 85 4 runner and has had cooling probs ever with a flex fan and electric fan on either side of his 4 core racing radiator
the w56 should handle the 4.3 no prob and will run better
but if you are hell bent on the 350 like i was until i got hit by a sudden urge of sense go with a turbo 350 tranny other wise the 4.3 is all you need
Sep 4, 2015 09:27 AM
shadowbirdie
Jul 21, 2015 10:38 PM
89hilux1
Jul 19, 2015 01:32 AM
Iceman4193
Jul 15, 2015 04:48 PM
