o2 sensor voltage
Old Aug 19, 2007 | 12:20 PM
MattMorty's Avatar
o2 sensor voltage
Hi, i just replaced my o2 sensor in my 90 3.0 4runner but the cel will not turn off. I checked the voltage and it is way too low. I think that is indicating a lean engine or a vacuum leak. Nothing i do changes the voltage nor could i locate any vacuum leaks. How do i get it in the right voltage range?
thanks matt
Old Aug 19, 2007 | 12:30 PM
4Crawler's Avatar
What voltage are you measuring and how are you measuring it? I use an analog volt meter and note that there are ~8 voltage changes in 10 seconds from ~0.2 volts to 0.8 volts. A digital meter may not show the rapid voltage changes, but you can watch the needle "twitching" on an analog meter. Or now, I have an Air/Fuel meter connected and just watch that while driving.
jb451
7
Oct 7, 2022 06:58 AM
EatChipsNow
Sep 9, 2015 01:25 AM
Kreedy1
Sep 8, 2015 06:33 PM
moparbay
Sep 3, 2015 12:48 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
