Water vs Trans Temp Guages
A friend of mine gave me a autometer water temp guage but since i already have a coolant temp guage i used it as a trans temp guage is there anything wrong with this? about how they read? due to the difference between ATF fluid and coolant? Also whats the transmission temp suppose to be? Mines running around 180 driving and about 200 sitting in the driveway (on a 90+ day and with a front mounted tranny cooler) is it suppose to get that hot?
All it does it takes the temperature of whatever fluid the thermometer part is installed into. You could use it to take the temperature of your cooked steak if you wanted to.
Rob
Rob
And Rob great example with the steak!!
kinda like comparing an oral to a rectal thermometer... either one only reads the temperature of the surrounding environment. they are interchangeable (with a good wash ) it's just a matter of knowing where it was stuck and what is the normal temperature in that environment.
200 a/t fluid temp sounds a slight/tad higher than I'd like to see, but isn't bad considering the a/t fluid passes through the radiator.
*sorry for the bad mental image*
the1998sr5
15
07-14-2020 08:35 PM
the1998sr5
07-16-2015 06:20 AM
Poncho0206
07-10-2015 06:21 PM
Avenged
07-09-2015 07:55 AM
