asap help air conditioning hose???
Old Aug 22, 2007 | 01:11 PM
infiltrator's Avatar
this guy at freaking pep boys says i need a hose that runs from my compressor to my freaking air system. he says it needs replaced, and i need r134 and the dude tells me its gonna cost 500 bucks. for a hose and 134......
i dont know what to do...
how much is this hose? can i get it cheaper?
help!!!
Old Aug 22, 2007 | 02:22 PM
ROCK LIZARD's Avatar
Try this forum for good info. The mods are great about answering:
http://www.autoacforum.com/index.cfm...=Yes&forumid=1
The company (AMA) makes custom hoses and does installs. Since AC is their specialty, I have used them instead of dealership (big bucks!) and general shops like PEPBoys. I see you are in Calif so maybe there are similar shops near you. Check around--$500 sounds steep unless you need other AC work.
Old Aug 22, 2007 | 02:28 PM
TORTIS's Avatar
are you going from r12 to 134?
Old Aug 22, 2007 | 03:02 PM
no my 95 already had the r134.. i guess i need this hose from the compressor to the evaporator? thats what the dude said...
this is bull.. if i take it to the toyota dealer, i have to pay another 85 dollars for "their diagnostic" WHEN I JUST DID IT AT PEP BOYS!!!
the hose i think i need they say costs 120 bucks!
that coupled with 140 for r134 should be like 300, but with labor its going to be more like 4-500....
i hate my life...
i have no money. :[
Old Aug 22, 2007 | 03:08 PM
i was not expecting this... 120 bucks for a hose... a hose is a rubber straw in a sense... right? is there something i am missing? is everyone out there a cheap scape??
how can i find a place like this? i looked, but this is arizona.. im still looking...
Old Aug 22, 2007 | 04:59 PM
TORTIS's Avatar
what is wrong with the hose? i had the metal tubing on mine split and paid a guy $20 to weld it up, been fine ever since. are you going to put it on yourself, or have them do it.
Old Aug 22, 2007 | 05:05 PM
well, i was going to ask, how big of a job is it to fix this? its just a freaking hose right? whats the big deal? is it hard to fix. seems like the mechanics all say "its an hour job" and i htink thats bs.. its a hose. doesnt cost that much does it?
Old Aug 22, 2007 | 05:42 PM
TORTIS's Avatar
there are enough brains on here we should be able to get you thru it. save ya some cash. you should have a hose repair place there in your town. they might be able to repair your hose.
Old Aug 22, 2007 | 06:04 PM
hmm ill check on that, in the meantime where do i start?
Old Aug 22, 2007 | 06:28 PM
is there some kind of manual that shows this? honestly is it worth the money to take it somewhere??
Old Aug 22, 2007 | 08:00 PM
InternetRoadkill's Avatar
The Pep Guy dude is full of #$^$%^.
The hose is going to cost around $100 +/-. You can send the old hose to an a/c shop that makes hoses and probably get it refurbished for less. I don't know the cost, but that's what I'm going to do with mine.
Changing the hose is easy, but you'll want to replace the o-rings that seal the joints. Get some stuff called Nylog-blue to insure the o-rings seal properly.
Recharging the system should also cost around $100. R134A is cheap.
Old Aug 22, 2007 | 08:13 PM
pennywize's Avatar
if its an AC hose theres more than replacing the hose. after everything is reinstalled you have to pull a vaccuum on the system for an hour or two to ensure there is no moisture or air in the system, then recharge with refrigerant. it is expensive, whenever an AC dies in my vehicles i just live with it, it only gets to be 110 for about a week a year where i live so it snot too bad.
but the original AC in my '79 still works!
Old Aug 22, 2007 | 08:35 PM
thefallman's Avatar
msg me i got a set of hoses from a tacoma 134 system that might work for you. the tacoma 3.4 engine uses the same ac pump as the 3.0 134 system. ill try and dig them out this weekend. if i find them just pay me shipping on them.
Old Aug 22, 2007 | 08:41 PM
oh really!!! omg your serious??? ill pay you for that asap!!! where can i get you the money??? this is a godsend!
by where on gods good name did you get the hose at?
oh yeah, i was gonan buy tubing for this hose, and the dude said no, because he said it wouldnt be strong enough.
i was going to buy it at that link above (like 2nd post), but hell if someone has one, great!!!
how can i replace this hose and r134?
Old Aug 22, 2007 | 08:45 PM
Replacing the rubber tubing on the hose requires a crimper. The hose is a special type called "barrier hose" which is made specifically for a/c systems.
Old Aug 23, 2007 | 02:17 AM
TORTIS's Avatar
i think your are going to have to replace the drier and expansion valve/thermocoupler. you can these at any parts store pretty cheap
Old Aug 23, 2007 | 06:30 AM
Mongrat's Avatar
If its the "Hose" I did its an aluminum one and its expensive.
Instead of replacing it a 2nd time we took it off and found a guy that could weld aluminum, he put a big fat bead on there and we recharged it with the $50 retrofit AC kit.
Ice Cold.
Old Aug 23, 2007 | 08:22 AM
Georgiadave's Avatar
You Could Have a Hose Made
Check around for a hydraulic and A/C hose maker, probabally in the SF Valley, take them the old hose for reuse of the ends, or to be sure that the new ends are the same, and have them make you a new hose. This should cost around $100.
Old Sep 6, 2007 | 10:26 AM
how hard is it to take out this hose? could someoen post a pic?
the1998sr5
15
Jul 14, 2020 08:35 PM
terminator
Jul 27, 2015 07:13 PM
gmonnie123
Jul 26, 2015 02:44 PM
yourrealdad
Jul 21, 2015 11:13 AM
skoti89
Jul 8, 2015 12:05 AM
