Truck won't go into 4WD
Old 08-21-2007, 12:35 PM
intense's Avatar
Hey folks,
My 4Runner has recently stopped going into 4WD (hi or low). I've only used it a couple times to help pull my boat out of the water at the launch. But it's never given me problems before.
Now, when I slide the selector into 4WD nothing happens. There used to be a clunk and the 4WD light would illuminate on the dash.
I thought I saw a thread on this a couple months ago, but I can't find it now.
thanks for your help!
mike
Old 08-21-2007, 12:38 PM
4Crawler's Avatar
Assuming an automatic differential disconnect (ADD) front end, see below:
http://toyota.off-road.com/toyota/ar....jsp?id=399612
Old 08-21-2007, 12:59 PM
intense's Avatar
Thanks for the link
My truck is a 1990. I think they started using the ADD later, no?
Old 08-21-2007, 03:06 PM
Elvota's Avatar
Do you have to manually lock your hubs? If yes... then no ADD.
What tranny/ transfer case do you have?
If you aren't sure, just tell us which engine and if you have a auto or 5spd.
We'll assume everything is stock in regards to the drivetrain and help you figure it out.
Old 08-22-2007, 05:53 AM
intense's Avatar
More details:
1990 4Runner with auto locking hubs, automagic
Also, it's a 3VZE
Everything in the drivetrain is stock....although, I did add an external piggy-back tranny cooler
Old 08-22-2007, 06:11 AM
4Crawler's Avatar
Originally Posted by intense
Thanks for the link
No, automatic hubs were only used up through '88/'89:
- http://www.4x4wire.com/toyota/tech/autohub/
Old 08-22-2007, 06:48 AM
intense's Avatar
Oh...ok
That puts me back at square one..
Old 08-22-2007, 09:44 AM
4Crawler's Avatar
Follow the troubleshooting steps on the first web page I posted a link to. Likely a vacuum line has come off or has been connected wrong. Or lock the ADD actuator in permanently and slap on a set of manual hubs and you won't have to worry about it:
- http://www.4x4wire.com/toyota/tech/add/
zd92655
03-06-2022 12:58 PM
Valvoman
06-28-2015 02:45 PM
TheManOutside
06-18-2015 03:32 PM
Quick Reply: Truck won't go into 4WD
