this bar seems as if it's in my way of wheeling...
Old Aug 13, 2007 | 03:13 PM
yota yota yota's Avatar
that blue bar going from the back to the middle... i looked at lots of other peoples rides and they dont have them bars... can someone tell me what are they for? just bought the car.. thank you all
Old Aug 13, 2007 | 03:19 PM
bob200587's Avatar
Traction bars I believe....
Old Aug 13, 2007 | 03:25 PM
1eye's Avatar
They look like traction bars to me, but I would need to see some more pictures of how they are attached to the rear axle. Anybody else want to throw in their 2 cents?
btw: Nice looking "truck".
1eye
Old Aug 13, 2007 | 03:29 PM
Texas_Ace's Avatar
My money is on traction bars as well but we will need better pics to tell for sure.
Old Aug 13, 2007 | 03:30 PM
i'll take some pics tomorrow... girl took the cam with her to the OC. traded a toyo mr2 turbo for the truck... bought the mr2 for 4k.. not sure if its a good trade or not... too late if it is...
1eye
Old Aug 13, 2007 | 03:40 PM
SuperBlue's Avatar
I think you could have got some cash plus the truck for an MR2T, depending on the year, condition and mods. If the truck drives as good as it looks then I think you got a decent deal.
I think everybody is on the money, traction bars reduce axle wrap and/or funky axle movement. I believe you can just ditch them for better clearance offroad.
Old Aug 13, 2007 | 04:07 PM
Texas_Ace's Avatar
True but i have also seen where they help guys roll of things so sometimes they can help. either way you can leave them on if you use it as a Daily driver for better on road performance.
or take them off for orr road.
I personally will be getting a set sometime since i drive 90% of the time on road. What year is the truck? If you take them off i might take them off your hands.
Old Aug 13, 2007 | 04:20 PM
Slednutjetskier's Avatar
That truck is so pretty.. Street Queen.
Old Aug 13, 2007 | 04:51 PM
mr toytech's Avatar
it is deffenently a traction bar. and if you drive the truck hard at all with those big tires you will probably want to keep them. very nice truck by the way.
Old Aug 13, 2007 | 06:06 PM
truck is clean... its a 92 with 240K miles on the body and 20k on a rebuilt motor... only problems is the horn and oil gauge doesnt work...
Old Aug 13, 2007 | 09:11 PM
drew303's Avatar
i cant tell from the pic but i dont see leaf springs... I see what looks like a driveline painted blue
is it a 3 link?
Old Aug 13, 2007 | 09:35 PM
heres random pics of it...
Old Aug 13, 2007 | 10:09 PM
Elvota's Avatar
Like others have guessed, those are traction bars. Keeps the axle from rotating under torque and causing the springs to make an "S" shape. Can lead to loss of traction and even possibly break parts... yadda, yadda, yadda...
I have just been doing a lot of research on traction bars and just completed one for my own truck because I was having some issues off road. I think the bars you have will significantly limit your flex and in turn articulation. So in fact, they may give you issues off road.
Thing is as the suspensions cycles, your leaf spring shackles want to move back. That bar design allows for zero shackle movement. No movement, more bind... less travel.
You'll have to hit the trails and see what happens. They look easy enough to remove, so you could try the same lines with and without them... and see which way works best.
Old Aug 13, 2007 | 10:44 PM
the_gunslinger's Avatar
have you no shame? clean your parts before taking pics.
carrier bearing. is it a 2wd?
Old Aug 13, 2007 | 11:15 PM
4WD V6
Old Aug 13, 2007 | 11:19 PM
Elton's Avatar
ditto on the traction bar
Old Aug 13, 2007 | 11:33 PM
Four Runner's Avatar
Banned for being an asshat
Lightbulb Where are you and what're you going to do with the truck??
Traction Bars+Drivetrain Loop+Bigger/Wider Open Tread Tires equals desert toy.
Looks set-up for low axlewrap and solid traction at speed. If you're going to be the type who loves desert play versus crawling around, keep 'em. If you're going to use it at all off road, scrap 'em, as yeah you can use them to slide off stuff, but look at how the traction bars hold up under landcruisers and 4runners, most folks end up damaging and either swapping to just leafs or 4 linkng their rear ends for serious crawling. Unless someone really detailed that thing (doubtful) the dirt and dust, versus mud, grass, and plant life shows fireroad/hardpack dirt play.
*Random thought too, pull your brake drums and inspect your hydros, I see a wet backing plate and splatter in those pics. You might just have a bad brake piston, but it might also be the axle seals going. You can pretty much gaurantee it's the axle seals, those big meats put a lot of stress on the axles/etc.
IE.....
Old Aug 14, 2007 | 08:43 AM
drew303's Avatar
looks more like PO just thought they were cool =)
Old Aug 14, 2007 | 09:28 AM
ewong's Avatar
As been said before
Those are RANCHO traction bars - circa 1991.
They are "looong" so that the amount of lenght change required of the shackle movement is "minimized".
Bigger problem is that the bushings used (pre johnny joint days) dont allow for cross articulation - thus it acts a giant "sway bar".
Installer put the bolts on the shocks in the wrong way - the head should be on the bar side and the threads on the in side - thats why they had to BEND the tab over like that.
The bottom shock bolts dont work right either.
To get the bolt to stop rattling it has to be cranked TIGHT - thus preventing the shock from articulating on the bushing.
This can be fixed by WELDING the bolt to the tab so it functions like the OEM bottom shock mound did.
ladybugRC
458
Aug 21, 2020 10:41 AM
choppe777
May 16, 2016 08:00 AM
A2theK
Oct 14, 2015 07:10 AM
Obmi
Oct 4, 2015 11:30 AM
mdh
Sep 15, 2015 12:12 AM
