What is this connector?
Old Aug 19, 2007 | 08:08 PM
pyromjm's Avatar
Can anyone tell me where this is supposed to go?
Driver side as u can see its between the dizzy and airbox
Doesnt look like theres any metal on the connector?
Truck is running a really low idle at warm, just changed water pump/ timing belt, idler pulley
Old Aug 19, 2007 | 08:56 PM
InternetRoadkill's Avatar
It looks like the connector is still connected, but the wire has been pulled out of the housing. It's hard to tell from the picture what that is.
Old Aug 19, 2007 | 09:07 PM
pyromjm's Avatar
yeah thats what it looks like to me too
it attaches to some weird ball shaped thing right behind the thermostat
Old Aug 19, 2007 | 09:20 PM
runethechamp's Avatar
From the location it sounds like the oil pressure sender gauge.
Old Aug 20, 2007 | 07:46 AM
pyromjm's Avatar
what does it plug into? where?
Old Aug 20, 2007 | 08:45 AM
thook's Avatar
Look for a wire lead coming from the oil sending unit....the weird ball shaped thing. If there's not one....a wire lead...there should atleast be a flat terminal to plug into.
Another possibility is if you have ADD 4wd. It could be for the actuator switch.
Old Aug 27, 2007 | 04:09 PM
pyromjm's Avatar
This does connect to the the oil sending unit, as well as something else, its like a Y. Ill have to go check when i get back to my truck.
The oil gauge is working fine as well as the temp gauge. I dont have ADD.
Old Aug 27, 2007 | 04:35 PM
mr toytech's Avatar
looks like the plug for the add.
some drunk guy
Aug 3, 2021 06:09 PM
Obmi
Sep 10, 2016 04:40 AM
mct75
Aug 22, 2016 01:24 PM
Obmi
Nov 24, 2015 11:37 AM
moparbay
Sep 3, 2015 12:48 PM
