2 inch lift shackles?
Old Aug 17, 2007 | 06:14 AM
coonhound's Avatar
Bought some new to me rear leaf springs yesterday and they came with some quality looking lifting shackles. Now my brother seems to think I can't use them without extending the drive shaft or else I'll get axle wrap. Is this true or is he just being negative because he doesnt want my 89 yota to be higher than his danger ranger. If he's right I'll be crushed.
Old Aug 17, 2007 | 07:09 AM
chimmike's Avatar
depends on how much lift it gives you. He may be right.
Old Aug 17, 2007 | 07:23 AM
coonhound's Avatar
crap, I assumed if they were 2" shackles they give you 2" lift?
Old Aug 17, 2007 | 07:24 AM
04 Rocko Taco's Avatar
2" shackles give you about 1" of lift.
Shackles wil llift almost half the distance they are extended.
So if your stock shackle is 4 inches, and the new shackle is 6 inches then it is 2 inches longer, and will lift half that length, effectively 1"
Make sense?
Old Aug 17, 2007 | 07:26 AM
dropzone's Avatar
Fossilized
http://www.4crawler.com/4x4/ForSale/...es.shtml#FAQ14
your chances of increased axle wrap would be greater if you used a block. just be sure your pinion angle is good to go...
Old Aug 17, 2007 | 07:53 AM
Jay351's Avatar
Since the shackle will change the angle of the axle, you would be fine.
Old Aug 17, 2007 | 08:26 AM
coonhound's Avatar
thanks for the input everyone. Now for the next question. I'll have to get shocks with more travel in them correct? Do I only need 1" extra or 2", because I've had an add a leaf before with too much travel in the shock and they kept blow'n the eyebolts off. Rancho 5000
Old Aug 17, 2007 | 08:47 AM
4Crawler's Avatar
Can't tell if you are saying your old shocks had too much travel for the suspension or if the suspension had too much travel for the cold shocks. But the best way is to measure how long the shocks need to be, there is a link on how to do so on the web page below:
- http://www.4crawler.com/4x4/Rancho.shtml
Old Aug 17, 2007 | 09:56 AM
Roger, you are King of the world. lol.
Old Aug 17, 2007 | 12:37 PM
coonhound's Avatar
that'll do boys that'll do. Thanks for your help. time to start grinding and wrenching.
Ernie217
Aug 14, 2015 05:25 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
coffey50
Jul 28, 2015 10:55 AM
Yotoder865
Jul 9, 2015 07:51 PM
