1986 Pickup Problem
Old Oct 12, 2008 | 09:51 AM
Mudawg's Avatar
1986 Pickup Problem
I have a 1986 Toyota ext-cab. Its got the 22r engine. It wont idle like its suppose to. It runs great, but when its tryna idle it smokes a little. I was told it was carb smoke. Any advice?
Old Oct 12, 2008 | 09:57 AM
algranger's Avatar
what color is the smoke? and how is it idling? it could be a number of things
Old Oct 12, 2008 | 10:14 AM
abecedarian's Avatar
if it's black smoke out the tailpipe, you're probably running rich, so you could try leaning the idle mixture a bit to see if it stops. if it doesn't, your float may be too high or stuck and the bowl is overflowing.
keep an eye on your idle speed and timing whenever you're adjusting the carb.
Old Oct 12, 2008 | 10:21 AM
Mudawg's Avatar
Its a white smoke, I believe its runnin rich too. When its idlin it goes dead if I dont give it a little gas.
Old Oct 12, 2008 | 10:34 AM
white smoke? umm... sounds like coolant
are you loosing any coolant?
could be the intake gasket
Old Oct 12, 2008 | 10:39 AM
Mudawg's Avatar
No, nothin leaks on this truck. I'll check the gasket. well its not completely white, its more of a gray/white color. (Hard to explain)
Old Oct 12, 2008 | 10:42 AM
actually, I asked if you were losing coolant, not leaking... small difference in semantics...
... I was thinking more along the lines of losing coolant into the intake, thus the gasket question- no visible leak.
but okay, gray/white or blue/gray/white sounds like oil
so check your pcv valve / breather
Old Oct 12, 2008 | 10:44 AM
Mudawg's Avatar
I cant do it right now, (rainin outside) I'll check it and post my findins.
Old Oct 12, 2008 | 10:45 AM
if the pcv looks okay, then next up would be a compression check to determine ring state, and if they're okay, next in line would be valve seals and/or head gasket.
Old Oct 12, 2008 | 11:02 AM
Mudawg's Avatar
10-4 good buddy thanks for the info.
Old Oct 12, 2008 | 02:20 PM
Mudawg's Avatar
Thank you so much. That was exactly was wrong with it!
Jun 1, 2021 01:51 PM
Avenged
Jul 9, 2015 07:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Jnkml
Jul 6, 2015 01:20 PM
