checking for vacuum/exhaust leaks techniques
Old Oct 12, 2008 | 11:22 PM
taikowaza's Avatar
when checking for any exhaust or vacuum leaks, what are the best ways to pinpoint the culprits?
I seem to remember reading about spraying an aerosol or fluid and looking for bubbles or change in idle but I want to make sure. If there is a better way I'll follow that.
I'd like to find out the cause of the slight 'bucking' I am having on cold mornings until things warm up.
thanks
Old Oct 13, 2008 | 12:19 AM
Matt16's Avatar
You could up pinch off the hoses one by one where they enter the TB. If the idle goes up when you pinch off a certain hose, the leak is upstream of the pinch point of that hose.
The aerosol can idea goes like this; you spray an flammable evaporating aerosol (so the spray doesn't leave a mess) over the vacuum lines, if your idle jumps up a bit, the flammable spray found it's way into the intake via the leak.
Old Oct 13, 2008 | 08:08 AM
22mr2's Avatar
use a unlit propane torch and wave it around slowly where u think a leak is. The engines vacuum will pull in the propane and make a change in the idle speed
Old Oct 13, 2008 | 08:45 AM
slisdexia's Avatar
wish I'd thought of that unlit propane torch idea for my truck.... if you spray the lines down, do small portions at a time, and use quick sprays. don't hose the whole thing down at once, you'll never figure out exactly where your leak might be
Old Oct 13, 2008 | 01:52 PM
taikowaza's Avatar
thanks guys- I will try the unlit propane torch and listen to the idle speed for changes. I'll post back if I find anything.
jasonty
41
Dec 23, 2018 01:00 PM
stock87yota
Jul 31, 2015 10:08 AM
jjrbus
Jul 19, 2015 02:06 PM
nick b
Jul 11, 2015 04:38 AM
Coreyr384
Jul 10, 2015 11:13 AM
