Cruise Control Not Working-1995 4Runner
Old 10-09-2008, 07:02 AM
GorgeRunner's Avatar
The cruise control on my 1995 4Runner does not work. The dash light comes on but nothing else happens.
Never had cruise control before, any suggestions where I should start trying to solve this problem?
Thanks
Old 10-09-2008, 07:18 AM
4Crawler's Avatar
The Factory Service Manual will have a fill section on troubleshooting the cruise control unit. What sort of engine and transmission in the 4Runner? One thing to check is the servo unit under the hood. If it is vacuum operated, make sure there is a vacuum line hooked to it and that there is vacuum present with the engine running. If a manual transmission, check that the clutch switch is adjusted properly.
Old 10-09-2008, 07:56 AM
eric-the-red's Avatar
GorgeRunner, if you want a copy of an FSM for a 95 4Runner PM me an email address.
Old 10-09-2008, 11:17 AM
Thanks for the tips. It is an automatic, so I'll check that servo unit first. I have a Chiltons manual, it has the diagnostic codes, but I was hoping this might be common issue with a well known fix.
The 4Runner is a bit of a project vehicle and I'm down to the pesky little things like the cruise control, rear window, etc.
Old 06-30-2014, 10:20 PM
justjay's Avatar
Please help! I have a "94 4Runner with a "95 V6. Manual Trans. The cruise control light on the dash comes on when I turn the system on, but when I try to set the speed, the green "CRUISE" light on the dash flashes and wont set a speed. Is this a module failure? I dont have a lot of money and was hoping to fix this myself if I can. Thank you in advance for any suggestions!
Old 06-30-2014, 10:38 PM
scope103's Avatar
What do you think the "Cruise" light flashing means?
http://personal.utulsa.edu/~nathan-b...10cruiseco.pdf
Old 07-01-2014, 11:33 PM
justjay's Avatar
The flashing is most likely a trouble code, but since I was driving on the freeway I didnt want to take my eyes off the road long enough to count and time/space the flashes.
7/1/2014 Update- Drove the truck to the shop for other unrelated repair this morning (suspension) and tried the cruise control and it works just fine now. Shop found no stored trouble codes and no electrical issues anywhere other than 1 marker light out. I had found a list of trouble codes online and bookmarked the page to post here, but my laptop dropped the page! If anyone finds the page I would be grateful to find it again so I can print them out for future use!
Old 07-02-2014, 05:34 AM
scope103's Avatar
Originally Posted by justjay
...! If anyone finds the page I would be grateful to find it again so I can print them out for future use!
(Why do I even bother ...)
Old 07-02-2014, 06:48 AM
Gevo's Avatar
It's okay Scope... some people don't pay enough attention sometime..
justjay, people care to help strangers on these forums, you need to read everyone's post so they aren't wasting their time repeating themselves.
The FSM is very thorough in the cruise control dpt. You should find your answer there. If there is something you don't understand, write it here! Good luck.
Old 07-02-2014, 03:00 PM
justjay's Avatar
**Scope103- Sorry I missed your hint. Sure am hoping it wasn't sarcasm- I sure dont need to feel any more stupid than I already do. There are several links here I cant open. Not sure why, just get error messages. I was hoping for help, not (Why do I even bother...)
**Gevo- I do pay attention, but since I couldn't access anything before GorgeRunner's post, nor open any links I was hoping for a straight answer. There were several things I dont understand, but now thanks to these two replies, I just feel like a dumb blonde. Since I cant seem to keep up with you, I'll step out. Sorry I bothered you.
Old 07-02-2014, 04:01 PM
rworegon's Avatar
justjay, try opening the link in post #6 above and then look on page BE-61. Can you use the steps shown to get the code to reappear via the blinking cruise light?
Old 07-02-2014, 04:50 PM
scope103's Avatar
**Scope103- Sorry I missed your hint. ...
Okay, don't get too broke up about it. Don't forget that, for the most part, we're all mostly anonymous.
If you've got trouble opening links, say that. If you can't find a referenced page, then say that.
We're all trying to help (and you will be too, soon enough).
Charecter1
11-06-2023 10:08 AM
icentropy
09-16-2020 02:47 PM
coryc85
09-09-2015 06:24 AM
mengquis
07-13-2015 10:39 AM
cyclist231
07-07-2015 12:56 PM
Quick Reply: Cruise Control Not Working-1995 4Runner
