Idle cut off solenoid bolt? Weber 32/36
Old 10-04-2008, 10:59 AM
-=j0nnyr0773n=-'s Avatar
I know that this is where the Idle Cutoff solenoid is supposed to go but on my truck it is a flathead bolt and if I take it all the way out it has an o-ring on it and a small hole in the shaft of the bolt that looks as if it lets fuel through or something. It does adjust the idle slightly if I loosen/tighten it. Does anyone know what this is and how to properly adjust it. Yes I have been searching forums and google all day for the answer. Thanks.
weber.jpg?t=1223146591
Old 10-04-2008, 02:16 PM
abecedarian's Avatar
there's no adjustment to it.
Old 10-04-2008, 03:14 PM
Do you know what it is? Should I just keep it tightened up all the way then?
Old 10-04-2008, 06:30 PM
The bolt covers the hole that the optional (read- required for emissions compliance) fuel cut solenoid gets mounted in. It should be snugged down and left alone.
Old 10-04-2008, 08:02 PM
All right thanks a lot.
Old 10-06-2009, 12:00 PM
yodta's Avatar
mmm, that looks to me like one of the idle jet carriers.
it is for sure if you say there's a "shaft" inside with holes in the end.
that little shaft is actually an idle jet; you can pull it out and change them to other calibrated sizes.
keep it snugged up. you don't want it loose. this thing meters fuel.
(I just stumbled across this post looking for idle cut solenoid posts, and I realize this is old.)
Old 08-17-2011, 02:31 PM
Eg-r's Avatar
where do u wire the single wire to?? cause the factory idle cut have two wire
Old 08-17-2011, 02:34 PM
xxxtreme22r's Avatar
EDIT: I take that back. Wire it to a keyed 12v source. I tapped off my choke wire.
Old 08-17-2011, 02:46 PM
Eg-r's Avatar
Cool. That's where I tap mine to also. I wasn't 100% sure so I ask. But when I too my car to go smog. The smog tech still say it's still running rich. I've double check the float already..
kazuya2416
04-05-2024 02:17 AM
DrZero
18
07-24-2015 11:31 PM
v_man
07-23-2015 04:01 PM
mengquis
07-13-2015 10:39 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Idle cut off solenoid bolt? Weber 32/36
