shaking is driving me crazy!!
Old Oct 9, 2008 | 08:24 PM
hgpilot's Avatar
got a 93 toyota truck 4x4, new shocks front and back, custom built driveline, new tires , used set of aluminum rims, balanced and rebalanced, rotate tires, rotate tires on rims, front end gut says it's tires or rims, got a road force balance for 100.00 it helped a little, been dealing with this for two years, if I could sell it I would but who is going to buy a truck that shakes, this is not a vibration, this thing shakes......anyone have any ideas?????
Old Oct 9, 2008 | 08:27 PM
algranger's Avatar
slack in the steering system most likely
Old Oct 10, 2008 | 04:15 PM
Flash319's Avatar
u-joints? Driveshaft problem, have also had the transfer case mount fall apart and causes driveline shake.
Old Oct 10, 2008 | 04:20 PM
abecedarian's Avatar
were the rims checked for runout or out-of-round?
and what's "custom" about your driveline?
and yeah, worn suspension parts could cause a problem, particularly if the alignment angles aren't dead on perfect.
Old Oct 10, 2008 | 07:24 PM
iamsuperbleeder's Avatar
the whole truck shakes, or just the steering wheel shakes?
could be SOOOO many things, even after what you've replaced; steering-stabilizer, mis-clocked drive shaft, bad u-joints, and as mentioned above, what you you mean by "custom driveline"?
Old Oct 10, 2008 | 08:12 PM
myyota's Avatar
How about your wheel bearings, have you had them checked ?, the rear bearings in my 4Runner were so bad you could wiggle them up and down almost a quarter of an inch.
Old Oct 10, 2008 | 09:36 PM
andtheman1988's Avatar
My truck shaked like hell after a leak in my power steering ate away my upper control arm bushings i would check them out to see if there cracked or torn up.
Old Oct 11, 2008 | 10:13 AM
hgpilot's Avatar
driveline shop made me a thicker wall and bigger diameter driveline (and new joints) because i had been in before to have it straitened, he siad he could make me one that would be solid
Old Oct 11, 2008 | 12:35 PM
by "drive line" do you mean drive shaft?
"drive line" is more of a description of a combination of parts like the clutch (or torque converter), trans, u-joint, drive shaft, differential, axle shafts, and so on...
chukarhunt
Dec 8, 2019 11:39 AM
jasonty
41
Dec 23, 2018 01:00 PM
v_man
Jul 23, 2015 04:01 PM
kyletbert
Jul 17, 2015 11:39 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
