Heated Oxygen Sensor help needed
Old Oct 7, 2008 | 07:04 AM
jamnik's Avatar
4runner 1995
I have 4 wires,
Blue - ?
White - ?
2 Black - these are probably heater conection
Which one is signal?
Which one is mass?
I need to conect new sensor but wire colors are different
Old Oct 7, 2008 | 01:18 PM
jamnik's Avatar
now a reply for my own post :p
Blue wire is signal
White one is mass
2 Black sensor heating
Old Jul 13, 2009 | 08:17 PM
Faded's Avatar
Going through this myself right now...just curious as to what you mean by "White one is mass"?
Thank you for the post, BTW.
Old Jul 13, 2009 | 08:30 PM
shftatsix's Avatar
if your replacing it with a bosch the two black wires (stock) will go to the two white ones (bosch), no polarity so it dont matter which way you hook it up. The blue one (stock) will go to black (bosch) and the white wire (stock) will go to the gray wire (bosch)
Old Jul 13, 2009 | 08:43 PM
Faded's Avatar
I have a factory O2 sensor (BLU, WHT, BLK, BLK) and a truck from some dumb-a that cut the plug off the truck-side of the wiring harness... (BLK, BRN, WHT/RED, PNK/GRN).
Old Jul 17, 2009 | 10:44 AM
shftatsix's Avatar
i found your answer sir
The pink/green might be tan/green and the yellow/red might be white/red, my crap is probably just old and faded
Old Jul 18, 2009 | 08:49 PM
Faded's Avatar
Thank you for the pic, I appreciate your follow-up and I'm sure the next guy will too.
I've actually had it hooked up for a couple days now and I was able to get the info to hook it up right after searching here for a while.
Old Jul 18, 2009 | 09:33 PM
iamsuperbleeder's Avatar
wow, wierd, my Bosch was easy to install... it plugged right in
I tried one of the universal ones like that first, but it didn't want to work for me, so I just got a direct replacement
Old Jul 18, 2009 | 10:16 PM
nv4runner's Avatar
I'm guessing that mass means ground since the white is the ground wire.
Old Jul 19, 2009 | 12:43 AM
abecedarian's Avatar
And if you're using a universal sensor, there's always the wiring diagram that comes in the box....
Old Jul 19, 2009 | 12:59 AM
shftatsix's Avatar
he was asking about the truck side of the plug (pink, brown, yellow, black). the instructions that come in the box, Bosch at least, refers to the colored wires on the O2 side of the plug (blue, white, black, black)
BigArt70
Jun 30, 2015 09:51 PM
94hiluxZE
Jun 22, 2015 10:42 AM
LSUMatt1514
60
Oct 10, 2003 12:30 PM
HALMAN
Jun 14, 2002 09:02 PM
