TPS settings/ problem
Old Oct 11, 2008 | 02:30 PM
Troph's Avatar
So my truck was having the Idle/brake surge problem so i tracked it down to being the TPS. Plopped a new one in it fixed it but now i cant get my idle down under 3k or it will do the same surging problem. any suggestions?
Edit: Its a 92 22re 4x4 pickup manual
Old Oct 11, 2008 | 03:07 PM
just a 22re's Avatar
you have to take a ohm meter and test it to make sure its going to full close lol
Old Oct 12, 2008 | 09:33 AM
abecedarian's Avatar
as allan mentioned, you have to get the TPS adjusted properly with the throttle closed so that the ECU sees the signal from the TPS that the throttle is closed. If the ECU doesn't see that signal, it can cause the idle speed to hunt around.
since you said something about the brakes, you don't have a vacuum leak from the brake booster?
smthwsn357
May 1, 2024 07:28 AM
Gone Fission
Jan 12, 2023 10:34 AM
Sleaker
Aug 26, 2020 06:03 AM
jetpilot
Aug 15, 2015 06:48 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
