Best brake pads for drilled/slotted rotors?
Old May 30, 2007 | 02:38 PM
CRamsey's Avatar
Been doing a little research on brakes and I have a question. I have a 1988 4Runner, 22RE, 5spd. I'm going with the LC Engineering slotted/cross-drilled rotors in an effort to avoid the warping I've had on the last couple sets of stock rotors. I generally drive in the city, lots of stop and go, sometimes have to slam on the brakes. This has led to my warping problem.
My question is: What's the best type of pad to use with these rotors?
Thanks, Craig in NC
Old May 30, 2007 | 02:45 PM
Jay351's Avatar
Why not ask LC? Im sure they know what works best with their products better then anyone..
TNRabbit's Avatar
Ceramic. They chatter a little but they are excellent stoppers & extremely resistant to heat fade.
Old Sep 4, 2009 | 11:50 AM
koone_kenneth's Avatar
Exclamation dont use ceramic rotors
they heat up to much and have been the cause of rotor replacement, alot of toyotas have this problem but ceramic rotors were a big factor causing mine to warp
Old Sep 4, 2009 | 12:03 PM
snobdds's Avatar
Yea Ceramic rotors are bad, but Ceramic Pads are good.
Old Sep 4, 2009 | 05:43 PM
FredTJ's Avatar
Thanks, Craig in NC
Drilled and slotted rotors will not improve your braking performance at all. They will not prevent warping. Why do you think that they will ?
Regarding pads, the EBC 7000 series are second to none.
Fred
Old Sep 4, 2009 | 05:58 PM
SoCalR6's Avatar
I'm doin rotors, pads, and reman calipers up front. Shoul I also replace wheel bearings? Best place online to buy yota parts for 2nd gen runner?
Old Sep 4, 2009 | 06:23 PM
Jay351's Avatar
Yes you should. You will need new races and bearings and inner oil seals.
jashoeuh
Nov 18, 2024 08:08 AM
corey519
Aug 12, 2015 11:12 AM
ty1er
Aug 1, 2015 11:53 PM
ahriman
Aug 1, 2015 10:38 AM
harrisdawg
Jul 26, 2015 09:42 AM
