Best brake pads for drilled/slotted rotors?
Been doing a little research on brakes and I have a question. I have a 1988 4Runner, 22RE, 5spd. I'm going with the LC Engineering slotted/cross-drilled rotors in an effort to avoid the warping I've had on the last couple sets of stock rotors. I generally drive in the city, lots of stop and go, sometimes have to slam on the brakes. This has led to my warping problem.
My question is: What's the best type of pad to use with these rotors? Thanks, Craig in NC |
Why not ask LC? Im sure they know what works best with their products better then anyone..
Ceramic. They chatter a little but they are excellent stoppers & extremely resistant to heat fade.
dont use ceramic rotors
they heat up to much and have been the cause of rotor replacement, alot of toyotas have this problem but ceramic rotors were a big factor causing mine to warp
Originally Posted by koone_kenneth
(Post 51221180)
Yea Ceramic rotors are bad, but Ceramic Pads are good. |
Originally Posted by CRamsey
(Post 50539827)
My question is: What's the best type of pad to use with these rotors? Thanks, Craig in NC Regarding pads, the EBC 7000 series are second to none. :) Fred |
I'm doin rotors, pads, and reman calipers up front. Shoul I also replace wheel bearings? Best place online to buy yota parts for 2nd gen runner?
Yes you should. You will need new races and bearings and inner oil seals.
