wheres my fuel filter
Old May 29, 2007 | 06:16 AM
86 yota's Avatar
I was doing some routine maintenance on my 86 yota 22r and couldn't find the fuel filter anywhere. If any any one could help please. Also put some synthetic oil in the motor and she runs the best ever. Is there anything wrong with using synthetics in an older vehicle. What other maintenance needs to be done. also cleaned and lubed the hubs cause they wouldn't turn. Thanks Clint
Old May 29, 2007 | 06:23 AM
DeathCougar's Avatar
22R-Right by the fuel tank, small plastic filter
22RE-Mounted to pass side of block, under the intake
86toysr5's Avatar
my 86s had 2 filters one the passenger wheel well under the hood and one next to the tank
*edit* mine must of been weird cause both my 22r and 22re had them on wheel well and by the tank
Old May 29, 2007 | 06:25 AM
under the under? whats the under?
maxpower_hd's Avatar
The 1st thing I would suggest is getting a service manual. There are even free versions on the net. The manual will explain all general maintenance and what intervals thay should be performed at.
It will also show the location of the filter which is on the passenger side of the engine block. At least that's where it is on my 93. There is also an access panel in the fender well to make it a bit easier to get to.
Old May 29, 2007 | 06:38 AM
86toysr5's Avatar
ok i edited it
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
pyramid
Jul 30, 2015 10:05 AM
ddg71
Jul 24, 2015 01:24 PM
Fundy Rider
Jul 16, 2015 01:35 AM
