Funy Idle from my 87 22re runner
Old May 25, 2007 | 06:25 PM
co4rnr's Avatar
I had many issues with my TPS and that was all taken care of. (New OEM TPS) I don't have any codes stored or anything that shows up when I jump the diagnostic box. What happens is that when I am at Idle with the engine at operating temp, the engine revs between 500 and 1200 RPM's. The only other time this has ever happened before was when I was running the A/C. Any ideas?
Old May 29, 2007 | 01:50 PM
co4rnr's Avatar
I have thought about this over the weekend and still could not think of anything that could cause this funny/ rough idle. Has anyone else experienced this?
Old May 29, 2007 | 02:32 PM
linuxrunner's Avatar
Looping idle often occurs when you have the idle screw set too high. Check and see if it only does the looping and strange idle when your foot is on the brake. If this is the cause simply bring the idle down a bit. However be sure the TPS is adjusted correctly it can be very difficult to get it spot on.
Old May 29, 2007 | 05:39 PM
co4rnr's Avatar
Could this be a cause of a sticking TPS? The TPS was adjusted to spec and there are no codes present as of now.
Old May 29, 2007 | 05:53 PM
just a 22re's Avatar
vac leak????
Old May 29, 2007 | 05:56 PM
rdlsz24's Avatar
There is also an AC idle you could take a look at.
Rob
Old May 29, 2007 | 06:02 PM
co4rnr's Avatar
Thanks guys, I will have to take a look at the vac lines in the morning. However, my engine does not do this all the time, it seems only to do it when it is warmed up and when I come to a stop after driving for awhile.
Old May 31, 2007 | 10:39 PM
co4rnr's Avatar
The reason that I had a looping idle was becasue the dash pot was out of adjustment. Now all I have to do is replace the o2 sensor and adjust the valves.
Old Jun 23, 2007 | 09:01 PM
RD1970's Avatar
dash pot
My truck is dooing this same thing. Why did you have to replace you 02 sensor? What exactly does the dash pot due? I took mine off because I thought is was somthing for the a/c it was off for about a month then the idle started acting up. Should I put the dashpot back on and if so how do you adjust it?
sonic concepts
Aug 16, 2025 03:13 PM
Yont283
Sep 23, 2022 08:06 PM
JF9243176
Oct 8, 2017 04:21 AM
Sandman
Jul 23, 2015 08:15 PM
JF9243176
Jun 24, 2015 04:53 AM
