problems after swap
Old Jun 1, 2007 | 05:51 PM
spanish-road's Avatar
problems after swap
Well my truck is a 1991 toyota it has a 22re with a rv cam. I have just replaced my blown motor with a rebuild. I have set the timing to +-12 degrees and it runs fine for a 2 minutes or less them it starts to cut off and sputters then it dies. I pulled codes and its fine so it must be something else. I have ran out of ideas of what it could be, and now I ask for help.
Old Jun 1, 2007 | 06:09 PM
rdlsz24's Avatar
I had a similiar issue: https://www.yotatech.com/forums/f116/22re-timing-idle-issue-104627/
Edit: If you didn't mess with the distributer on the donor engine, then it most likely won't be that. Did you set the base timing by jumping the 2 terminals? I'm not familiar with aftermarket cams for the 22RE. Does the RV cam use the stock timing?
Rob
Old Jun 1, 2007 | 06:46 PM
wjhart3's Avatar
timing should be set to 5 degrees with the two terminals jumped-should be diagram on underside of hood showing which two to jump-if it wont run at 5 then dist might be off a tooth or timing chain off a tooth
Old Jun 1, 2007 | 07:24 PM
well I set it to the spces and at 5 degrees jumped the two terminals and set the dist at 12 o'clock and it moved ccw35 degrees and it runs at 1000 rpms and drops off to 750 then craps on me.
EDIT: the CEL was flashing every 1/2 second the whole time of the code pulling thing.
Old Jun 1, 2007 | 10:11 PM
Corbit's Avatar
5 BTDC with the terminals jumped is about 12 with out. It sounds like a fuel delivery issue , try and jump it so your fuel pump stays on .
Old Jun 2, 2007 | 10:07 AM
Well I jumped the +B and FP terminals the fuel pump was running and it solved that problem. Now how do I correct this problem?
Old Jun 2, 2007 | 12:17 PM
I have just fixed the problem. I followed the fuel pump to the ecu and fount it not pluged in all the way. I guess that type of stuff happens after 10 straight hours of work, silly me! thanks for the help!
Old Jun 2, 2007 | 10:45 PM
Corbit's Avatar
Glad to hear it was one of those , I do that all the time and have to laugh at myself for it. Where in Wa. are you ? I'm in Anacortes.
Old Jun 3, 2007 | 07:22 AM
Im in aberdeen at the last week of june Im going to Ocras for a family thing, I used to live in Anacortes past the ferry terminal on the south side near the flamingo boat launch.
Old Jun 3, 2007 | 12:59 PM
Corbit's Avatar
I'm going to be in Cali for a couple of days around then , but hit me up and we can go up to Walker Valley for some fun.
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
coryc85
Sep 9, 2015 06:24 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
