Automatic to Manual Hubs Question
Old Jun 4, 2007 | 12:34 AM
mrboyertown's Avatar
Question Automatic to Manual Hubs Question
Looking to chang my 94 V6 Pickup from auto locking hubs to manual. Did plenty of research on here and it seems pretty straight forward. The only problem is when i was looking for a pair of manual hubs on auto parts websites they all said i needed a spindle nut conversion kit? I got my pair of hubs from ebay (aisin) in the threads on here about the conversion it says nothing about changing the spindle nut over. Can anybody help me out here? Do i need a different nut or can i just throw on the manual hubs by using what I already have to work with?
Old Jun 4, 2007 | 12:56 AM
Elton's Avatar
never heard of anyone needing it
Old Jun 4, 2007 | 02:21 AM
91 4Runner's Avatar
For Asins, they are direct bolt on. (OEM) Warn (I believe) need the axle nut conversion. Make sure before you swap them, rebuild/clean them.... I've done this "swap" on my 90 4Runner - easy job. I would suggest keeping the autohub and cap for a trail spare....
Old Jun 4, 2007 | 07:18 AM
tombothetominator's Avatar
For ADD you do not need the spindle conversion kit. If you have AUTO hub (available on some 1st gen 4runners, but not 2nd gens i believe) then you need the spindle conversion. Or at least that's the way i heard it.
Old Jun 4, 2007 | 07:25 AM
mt_goat's Avatar
Yeah you probably don't have auto locking hubs, you should have ADD hubs which are always locked (live hubs) and auto diff disconnect (ADD). The auto locking hubs were a big failure in technology and Toyota stopped using them before 94
Old Jun 4, 2007 | 07:40 AM
dropzone's Avatar
Fossilized
Yes they were a big failure...went out with 12K on the odometer of my '86 4Runner 2 decades ago...
Old Nov 21, 2007 | 10:15 AM
DaHos's Avatar
I found a front 4.56 V6 axle with ADD.
Im rebuilding my 86 runner 4 cylinder which has 4.10's and auto hubs. I have a extra set of manual asian hubs. What do I need to do/get to install this with the 4.56 carrier.
Or if someone has a link, please pass it on.....
Thx, D
Old Nov 21, 2007 | 10:23 AM
Jay351's Avatar
To convert from ADD to manual hubs all you need is the hubs themselves.
remove the 6 bolts holding the flange on, remove the single big nut, then remove the 6 cone washers. Then just put everything back together with your manual hub.
Old Nov 21, 2007 | 10:51 AM
DeathCougar's Avatar
Thats correct for ADD, but Automatic hubs (84-89 4runner, 84-88 truck) are NOT THE SAME.
You will need the spindle nut conversion kit mentioned above.
Just visit WabFab.org, he will have all that you need.
He has the conversion kit for $30+$15 shipping.
Old Nov 21, 2007 | 10:53 AM
Thx, D
You will have to find some way to make the ADD work in your truck, since you have auto HUBS and not ADD. ADD is vacuum actuated, so if you could figure out a way to do that, it would work. But, IMHO, the ADD is a waste of time and effort. Better off to find a non-ADD 4.56 diff.
Old Nov 21, 2007 | 12:29 PM
DaHos's Avatar
This is what Im thinking.....
Use the 93 V6 ADD 4.56 carrier in the existing 86 housing/axles/tubes and add the manual hubs with a "conversion" kit......then NO ADD items to mess with..
Old Nov 21, 2007 | 01:13 PM
Actually if you just swap the jack and stub shafts and remove the ADD junk, you can use the main diff and not have to swap carriers i believe.
Old Nov 21, 2007 | 03:18 PM
DaHos's Avatar
Thumbs up
BINGO !
I think thats what I meant to say , just wanted to make sure it can be done...
Old Nov 21, 2007 | 03:19 PM
I know for a fact it can, i just went and compared the two diffs, and it can be done.
Old Nov 21, 2007 | 03:23 PM
DaHos's Avatar
Thank you for your time......Ill be picking up the runner on friday...
glowz825
Jan 25, 2022 09:28 AM
oldirtydirt
Feb 23, 2020 09:30 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
Poncho0206
Jul 10, 2015 06:21 PM
ItsJustD
Jul 7, 2015 07:49 AM
