wacky Air Filter idea....
Old Jun 4, 2007 | 09:58 AM
ewong's Avatar
http://www.cleanstream.com/filters_wetdry.html
Use a Gore Clean Stream as an air filter????
Does it flow enough?
Just curious...
Im going to ASSUME that it does not flow enough or Gore would already be doing this for automotive applications....
Old Jun 4, 2007 | 10:03 AM
notanymore's Avatar
you could try it and share your results
Old Jun 4, 2007 | 10:09 AM
WATRD's Avatar
Interesting and innovative thinking... You would have to confirm the flow and the filtration, but it's an interesting idea.
Old Jun 4, 2007 | 10:30 AM
Erich_870's Avatar
That filtration comparison using the pink dust was pretty impressive. Nothing made it through the cleanstream.
Like WATRD said, they need to compare flow on that same test set up.
Erich
Old Jun 4, 2007 | 10:42 AM
ewong's Avatar
engine air flow rates
http://www.ajdesigner.com/phpengine/..._flow_rate.php
cc to cid
http://www.4lo.com/calc/literstocid.htm
2.4L =~ 146CID
VE
http://www.installuniversity.com/ins...n_9.012000.htm
use .75 as a baseline
CID = 146
RPM = 5600
VE = .75
>> CFM ~ 180 ft^3 / minute
Shop vacs seem to be rated on "peak" HP and not SCFM...
Old Jun 4, 2007 | 11:14 AM
dijlop's Avatar
for those of us that are lazy and dont want to put in any effort for at least another hour or two(just got off work) hows the comparison of flow match up from the stock airbox to the actaully pretty good idea uve come up with?
Old Jun 4, 2007 | 11:25 AM
ewong's Avatar
Dijlop - I dunno - cant find what the flow rate of the shop vac might be so I cant tell uif there is enough filtration to support the engine...
Old Jun 4, 2007 | 11:29 AM
dijlop's Avatar
so what ur saying is that ur not sure if the filter will actually filter enough with the added sucking power of the engine over the shop vac?
or r u saying that the filter wont let enough air in to comply to the sucking power of the engine over the vac?
basically, r u not sure if enough air will get in, or if too much junk will get in?
y couldnt i compress that all in the first place? im not sure.
Old Jun 4, 2007 | 01:57 PM
notanymore's Avatar
i would think if anything it wouldnt let enough air in. i would think filtration isnt the issue because it clames to filter down to .3 microns and people are driving around all day with k&n which goes for flow over filtration
Old Jun 4, 2007 | 02:23 PM
dijlop's Avatar
lol. true. i still like the idea k&n has though. the oil. stick ur hand in a pile of feathers. now get ur hand wet and stick it in a pile of feathers. thats the k&n difference.
Old Jun 4, 2007 | 05:51 PM
notanymore's Avatar
very true, but the oil can dry out if not oiled often enough but o well i still use them
Old Jun 4, 2007 | 05:53 PM
ewong's Avatar
My guess is it wont flow enough..
Sent an email off to Gore (filtration division)....
Old Jun 4, 2007 | 06:01 PM
dijlop's Avatar
lol. good idea. go straight to the source. msot deff have to keep them oiled. speaking of which i should proally clean mine and re-oil. another 10 bucks down the drain. oiy.
Old Jun 4, 2007 | 06:18 PM
notanymore's Avatar
it makes no sence they give you a big bottle of cleaner and a tiny bottle of oil... o well
Old Jun 4, 2007 | 06:20 PM
dijlop's Avatar
cause the oils real strong. hehehe. that was meant to be said with one of those old man on a commercial imitation that u see in the movies accents. yea.
Old Jun 5, 2007 | 12:50 AM
ovrrdrive's Avatar
To make that a fair comparison you'd have to have holes in your hand big enough to let some of the feathers through...
Old Jun 5, 2007 | 06:34 AM
tombothetominator's Avatar
HAHAHAHAHAHAHA, freakin helarious.
Old Jun 5, 2007 | 07:16 AM
jagger_snitt's Avatar
Have you guys ever heard of No-toil? It is a company that makes air filters and air filter maint. chemicals for dirt bikes.
I've used their products and they're great. They make a filter oil that is water proof and that can't be removed by anything except their cleaner.
I've been toying with the Idea of running an airfilter setup with their product.
The stuff really works... There cleaner makes the stuff come right off too.
This might be something you guys would be interested in.
Old Jun 5, 2007 | 07:37 AM
04 Rocko Taco's Avatar
also sounds very viable...again, Im assuming the flow would be sufficient, but I know nothing about dirtbikes, but surely they dont flow the same air as a 3.4?
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
accuracy
Aug 4, 2015 08:05 PM
Toyvana
Jul 29, 2015 10:47 PM
ryerye13
Jul 14, 2015 08:27 AM
