Rebuilding 86 22R-TE
Old May 31, 2007 | 06:32 PM
PeanutRanger's Avatar
Smile Rebuilding 86 22R-TE
1986 Toyota 4Runner
143,XXX mi.
Turbo SR5 (If anymore info wanted to just ask)
Hello To All, my Dad and I are about to ventur into rebuilding my turbocharged engine, in my 86. I was wondering if you guys might have a parts lists from yall's rebuilds, any useful tips from past experiences? At the monment I am mainly just trying to gather all the parts I am going to need for this rebuild. Any info at all is greatly appreciated! Thanks alot!
Old May 31, 2007 | 07:21 PM
dcg9381's Avatar
The 22RTE isn't very different from the 22RE or 22R rebuild. The main part that you may have trouble finding (and may be incorrectly listed as the same as a 22re) is the oil pump.
www.engnbldr.com has complete rebuild kits for that motor at very reasonable prices. He sells quality stuff. Consider upgrading to his stainless valves, otherwise be sure to keep your 22RTE exhaust valves.
Other advice is to take a TON of photos during teardown.
You really can't buy parts until you've got it torn down as you'll need to order the correct oversize of bearings and pistons.
Have the turbo checked out while the motor is out. It's much less expensive to replace seals and bearings now.. If you wait until it fails, the price will go up by about 300%.
Old Jun 1, 2007 | 04:49 PM
Bill's Avatar
I rebuilt my 22RTE using Teds parts, and it's working out pretty well.
Due to some nastyness, I replaced my stock timing cover with an EB 22R/RE/RTE cover. I also used an EB turbo oil pump, according to Ted it puts out about 4% more oil...enough to make a difference I don't know, but it's working, and it's only a couple $$$ more than a regular EB pump.
Old Jun 1, 2007 | 06:39 PM
wjhart3's Avatar
ted sells some great stuff and backs it up--
Old Jun 1, 2007 | 08:42 PM
Numbchux's Avatar
x eleventybillion!!!!!!!
I did a bunch of work on my truck this winter, just to find that the turbo is toast. which means that it'll remain out of commission until I can afford to do something about it (most likely just drop in a 22RE).
Old Jun 4, 2007 | 05:51 PM
This Teds part, is that the from the website listed in the second post?
Old Jun 4, 2007 | 05:57 PM
Bill's Avatar
Yup, Ted is Engnbldr, www.engnbldr.com or email him engnbldr@engnbldr.com
Dale Johnston
11
Oct 31, 2015 10:22 PM
the_supernerd
Oct 1, 2015 09:20 PM
ktm192k
Oct 1, 2015 08:47 AM
tylermx71
Sep 29, 2015 08:49 PM
voiddweller
Sep 28, 2015 11:21 PM
