Weird idoling problem(seem weird to me)
Old Jun 3, 2007 | 05:30 AM
yotakid825's Avatar
When I put on the brake it's starts to idol funny(not funny haha) then when I let off the brake it idols high at about 1500-1600 rpm. when my foot is on the brake it drops to about 800-900 rpm and then up to around 1200-1300 rpm then back down to 800-900 rpm. I really have no idea what's causing this please help
Old Jun 3, 2007 | 06:00 AM
TNRabbit's Avatar
THis is a common problem with an automatic tranny (that's what you have, isnt' it?). I don't know the exact fix, but I'm sure someone will come along soon with your solution.
Old Jun 3, 2007 | 06:15 AM
yotakid825's Avatar
I have the 5 spd tranny and the engine is a 22re
Old Jun 3, 2007 | 06:17 AM
TNRabbit's Avatar
I'd bet you have a vacuum leak. Run an UNLIT propane torch around the intake & all vacuum lines; if it idles up, you have a leak there. Check the brake booster line first.
Old Jun 3, 2007 | 06:35 AM
superjoe83's Avatar
your idle is too high, turn it down and i bet this will go away, the computer is hitting fuel cut, it thinks that your decelerating in gear....
Old Jun 3, 2007 | 12:02 PM
notanymore's Avatar
yeah sounds like your idle is too high to me. it should normally idle around 750 or something like that, not 1300
Old Jun 3, 2007 | 04:11 PM
yotakid825's Avatar
I started and drove the truck around a bit before I went to work and it didn't have the idoling issue so I don't know
Old Jun 4, 2007 | 06:48 AM
NCSU-4runner's Avatar
idle not idol
Old Jun 4, 2007 | 10:14 AM
yotakid825's Avatar
Originally Posted by NCSU-4runner
idle not idol
hahahahaha I was waiting to see who would catch that
Old Jun 4, 2007 | 11:16 AM
gravy's Avatar
my 86 runner with a 5spd 22re does the exact same thing. its like rrrrrrRARrrrrrRARrrrrrRARrrrrr.
Old Jun 4, 2007 | 11:19 AM
mtnfreak's Avatar
You're caught in the fuel-cut/fuel-return loop. You most likely have an intermittent vacuum or air intake leak. Try the propane trick or use a spray bottle to mist some water around. The mist will get sucked in and cause a quick RPM drop.
Jonny246
Jul 24, 2015 12:37 PM
yourrealdad
Jul 21, 2015 11:13 AM
kyletbert
Jul 17, 2015 11:39 AM
icentropy
Jul 14, 2015 10:23 AM
jon.r
Jul 11, 2015 03:34 PM
